Basement Egress - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-24-2008, 01:12 PM   #1
Basement egress
I need to remodel my basement to move my mother in law in and I need add an egress for her. bilco doors wont work. Any one know where I can get plans to add door and stairwell ?
caminoguy1 is offline   Reply With Quote
Old 05-24-2008, 02:32 PM   #2
Jay123's Avatar
Try some of these:
http://www.google.com/search?q=basem...ient=firefox-a
J
Jay123 is offline   Reply With Quote
Old 05-24-2008, 06:56 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
If you have an exposed side to your foundation:
http://www.naturalhandyman.com/iip/i...ecutting2.html
Egress Window kits and systems:
http://cutandcore.com/egress.htm
http://www.windowscapellc.com/site/1...roduct/WSPKG2S
- Build Well -
Old 05-24-2008, 06:58 PM   #4
Jay123's Avatar
I'm pretty lucky here in Atlanta, I have never seen a basement without plenty of daylight...always a door and most of the times, multiple windows.
J
Old 05-25-2008, 01:15 AM   #5
Registered User
Termite's Avatar
Are you adding the door in the bedroom? Adding a door in the living area won't satisfy the code of there is a sleeping area in the basement. There must be compliant egress to the exterior from the sleeping area(s).
Living spaces are not required to have egress doors or windows if sleeping areas with egress are present.
You can satisfy the egress requirements with an egress window in the bedroom. If below grade, it must have a 5.7 square foot opening, and the bottom of the opening must be no higher than 44" off the floor. The window must be operable without special tools, hardware, methods, or knowledge. The egress opening must be obtained with normal operation of the window (sash removal or tilting sashes typically aren't considered normal operation). You must have a minimum 36x36" egress well, and a compliant egress ladder if the well is 44" or deeper.
If you're planning on putting the egress door in the exterior bedroom wall, you'll meet the code requirement.
Old 05-31-2008, 11:41 AM   #6
basement egress
thanx for all your help guys. I'll have my mother in law living downstairs in no time.
Old 05-31-2008, 06:36 PM   #7
Registered User
Termite's Avatar
I think there's an exemption in the code for egress requirements when boarding unwanted mother-in-laws.
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
Wet Basement being fixed (pics) harleysilo Remodeling 2 01-23-2007 09:09 AM
