Basement Door Lift Install - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-13-2011, 09:26 PM   #1
Basement door lift install
Need help on a system for opening a basement door that is apart of my floor in one of the rooms. It opens up with a tug on a handle but was wondering about some sort of strut or actuator system that can be operated from inside the basement and outside the basement as well (Tornado's prevalent in my area and need to take cover). Any help would be great. Thanks.
enemydream is offline   Reply With Quote
Old 03-14-2011, 06:13 AM   #2
Gas struts would reduce the effective weight of the door, making it easier to open. They are usually sized for the weight they will support and the travel length.
Old 03-15-2011, 12:15 PM   #3
Thanks. Is there any sort of automated system that would work as well or that could pop the door open so the gas strut could take over? Thanks again.
Old 03-15-2011, 01:37 PM   #4
You want a handicap door system on in? Push button open?
pjordan4477 is offline   Reply With Quote
Old 03-15-2011, 04:40 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You want an "automated" system so that when a tornado does strike and the power goes off, the door won't open???
XXX
Old 03-16-2011, 10:18 AM   #6
Great point!!!
Old 03-16-2011, 06:00 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Great point!!!
That's why I get paid the big bucks.
Little old lady calls the fire department to tell them her cat is stuck in a tree and asks if they will come and get her cat out of the tree.
The fireman on the other end of the phone says: "We sure will ma-am, How do we get there?"
Little old lady says: "Don't you guys have that big red truck anymore?"
XXX
Old 03-17-2011, 03:19 AM   #8
Not necessarily like that, I figured if the power went out then a simple push on the door would open it (if the gas strut were installed). But for more everyday ease of use I was wondering of an automated system. Basically I was just looking to see what other people have done and what was out there already. Thanks again.
Old 10-06-2011, 07:24 AM   #9
You have your point about the ease of use on Basement doors. But be sure that you can still access when the power turns off.. Just ask the professionals on it.
Basement Entry Systems
Basement Doors is offline   Reply With Quote
Old 10-06-2011, 10:17 AM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Been seven months and the OP hasn't returned, I wonder if that sucker is trapped in his hidden room with the automatic door that won't open?
The Following User Says Thank You to Bud Cline For This Useful Post:
AGWhitehouse (10-06-2011)
Tags
actuator , automatic door opener , basement , cellar , lift
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
Rigid foam Install in Basement Chasester Building & Construction 8 12-16-2009 08:07 AM
New Basement Sink Install handymanguy Plumbing 2 02-14-2009 09:27 AM
Dehumidifier install in basement? gone_fishing Remodeling 3 03-09-2008 07:25 PM
Want to install larger window in basement wall andrewcocke Remodeling 8 02-24-2008 10:51 PM
