Basement Condensation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-14-2010, 02:11 PM   #1
i am finishing my basement and it always stays nice and dry all summer and most of the time in the winter. Except when it gets really cold. When it gets cold and starts to warm the condesation on my walls gets pretty bad. I want to install engineered wood floors however amy worried about damage and mold during this rare occurence. We just had a cold snap and I had 2 different spots on my wall that condestin ran down the wall. ANy suggestions how to control this. I was told once I insulate the interior walls I should not have the problem anymore?
chadlefler is offline   Reply With Quote
Old 01-14-2010, 02:19 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
Poor air circulation in the basement and excessive moisture in the air. Do you have adequate cold air returns in the basement?
Since you have finished the basement, you want it to be a conditioned space. Wood in meant to be installed in a conditioned space with circulation.
Dick
concretemasonry is online now   Reply With Quote
Old 01-14-2010, 02:24 PM   #3
I do have good cold air return and vents in every room. It is a 9ft basement
Old 01-14-2010, 02:59 PM   #4
Remodeling Contractor
insulating the exterior walls with 2" of spray foam or 2" rigid foam will help. Otherwise you need to use a dehumidifier. Humidity must be kept below 50% for comfort and mold prevention. Warm moist air hitting a colder surface will condense. Warm the cold wall and/or remove the excess moisture.
Old 01-14-2010, 06:25 PM   #5
Could I possibly under ventilated in my attic. My hous is 10 yrs old the contractor at the time did not add sophit insulation. He said that was the old way, It has ridge cap ventilation?
Old 01-15-2010, 07:50 AM   #6
The attic requires a balanced vent system. The intake through both soffit vents should match the exhaust out the ridge vents.
Old 01-15-2010, 09:21 AM   #7
So could this cause a problem in my basement? How do I know if I have enough ventilation? Is there a way to test
Old 01-15-2010, 09:22 AM   #8
A blower door test. Contact a local BPI contractor.
Old 01-15-2010, 10:40 AM   #9
BPI? Also mentioning that I also notice that I have an exterior door that is difficult to shut. Because of air pressure. Could this be a sign of anything
Old 01-15-2010, 10:42 AM   #10
Same contractor can address all of this. BPI -- Building Performance Institute
Old 01-16-2010, 03:31 PM   #11
Registered User
Rewards Points: 5,216
You can check some things yourself: http://www.fureyco.com/content/image...ng_The_Air.pdf
The math: http://www.airvent.com/homeowner/pro...it-specs.shtml
Some problems: http://www.blocktheheat.com/ventproblems.htm http://www.ronhungarter.com/black_mold.html
http://www.buildingscience.com/docum...on?full_view=1
Stack effect: http://www.buildingscience.com/docum...on?full_view=1
Be safe, Gary
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 09:49 AM
Basement Vapor Barrier Condensation waynor Building & Construction 10 02-02-2009 11:02 AM
Basement condensation buckyboy Building & Construction 5 06-19-2008 02:35 PM
condensation leaking in basement! geniedee HVAC 3 08-25-2006 08:58 PM
