Basement Concrete Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-19-2011, 07:25 AM   #1
Question
basement concrete beam
I want to span 17' with a large concrete beam. I plan to insert a heavy duty rebar cone, arch the ends and connect it to two large piers formed with sonotubes resting on wide and thick footers. Everything tied in with #6 rebar. I want the beam to be exposed and am going to use terra cotta concrete to match the walls.
I am a concrete man, but not a structural engineer.
I need to know:
1. What should the dimentions be on the pier and beam
2. What size rebar should be used
3. What size sonotude should be used
rugs 1986 is offline   Reply With Quote
Old 07-19-2011, 08:18 AM   #2
DIY staff
Rewards Points: 7,174
To get any technical suggestions you need to include the load the beam will support.
Is the beam holding up a house----roadway----foot bridge?
Add some details,please.
Old 07-19-2011, 09:11 AM   #3
AGWhitehouse's Avatar
I'd be surprised if you got all that info here...that's how some people make their living. Comparative analysis is one thing, but outright design is another. Please call a structural engineer...
AGWhitehouse is offline   Reply With Quote
Old 03-25-2013, 11:59 AM   #4
Rewards Points: 1,002
The beam should be 17' long
Buy either the 10' or 20' sticks
Cut to length
Hope this helps
Anti-wingnut is offline   Reply With Quote
Old 03-25-2013, 09:24 PM   #5
Concrete & Masonry
Rewards Points: 470
I was hell-bent to form and pour a concrete lintel/beam for 2 - 18' OH door openings on my shop years ago. After paying an architect for the drawings, along with an SE to stamp the beams, I ended off opting for steel I beams with bearing plates welded to the bottom, and "soaps" (narrow block) laid on the plate. The concrete beam was WAY bigger than I expected, and actually more expensive than the steel........
jomama45 is online now   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
AGWhitehouse (03-26-2013)
Question about steel I BEAM in basement djohns10 Building & Construction 7 06-23-2012 04:55 PM
Laminated flooring over basement concrete Woodcutter Flooring 2 10-25-2011 09:55 AM
Finishing basement - concrete walls options droyer Building & Construction 1 01-13-2010 07:27 PM
Concrete Basement Beam jrepp44 Building & Construction 1 01-06-2010 02:39 PM
Temporary support for replacement of basement beam Mikedks Remodeling 8 09-14-2006 07:36 PM
