Basement Cold Joint Repair Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-12-2011, 05:52 PM   #1
basement cold joint repair question
Last spring/summer my brother in-law help me install a sump pump which helped with most of our basement leaking issues. I noticed that we still have an issue with water seeping through at the cold joint during the heaviest rain storms. I got some Drylok fast plug to seal this joint and when looking at the directions, they show using it on a non-painted wall/floor. When I moved in, my basement's walls were thickly painted (textured) and the floor also has a nice coat. So my question is, should I chisel off the paint before applying Drylok? Does it really matter? Thanks.
russ.starr is offline   Reply With Quote
Old 03-12-2011, 09:18 PM   #2
Foundation repair
It sounds as though your problem may be within your drainage tile. May i suggest scoping the tile to insure no roots or debris have inhibited flow. If the flow is fine epoxy seal cracks and at the extreme dig the fill in the suspect area and tar/membrane the foundation.
finishingtheunf is offline   Reply With Quote
Old 03-12-2011, 10:05 PM   #3
I already had someone tar/membrane the cracks from the inside and outside. I'm a newby... how do I go about "scoping" the tile?
Old 03-13-2011, 07:15 AM   #4
Rewards Points: 4,656
plumbers have tv cameras,,, a sump along rarely resolves leaking wtr issues,,, to properly seal a cold joint, inject w/hydrophyllic polyurethane,,, the wtr will stop leaking in that spot however it will find another path of lease resistance at some future time.
' drylock ' materials do have their place however its usually on the apron/vest 's shelves,,, pro's RARELY use them,,, in face, if h/o's didn't buy them, they wouldn't be avail,,, even IF they did work, the wtr still penetrates causing damage you can't see.
then again, out of sight often = out of mind
Relace vs Repair: PVC heating exhaust joint mcgrete HVAC 2 01-16-2011 09:55 AM
cold air return vents in the basement samantha.77 HVAC 5 01-07-2011 10:51 AM
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 04:58 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-22-2006 11:03 PM
