Basement Cinderblock Replacement Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-01-2011, 01:43 AM   #1
I'm planning to remove some of the old rotten cinder blocks in the basement. The mortar between these blocks are completely deteriorated, and blocks are broken and falling apart (rotten). I'm planning to replace these blocks in the basement. Please give me some advices, what should I do? I also see the mortars between blocks are falling apart.
CannonD is offline   Reply With Quote
Old 04-01-2011, 09:22 AM   #2
Stay-at-home GC
How many blocks are we talking? Pics? Also need to know which direction your floor joists are running as this will determine how much weight is bearing in the wall.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 04-01-2011, 03:22 PM   #3
here are the pictures
Basement Cinderblock Replacement Help-dsc00738.jpg   Basement Cinderblock Replacement Help-dsc00739.jpg   Basement Cinderblock Replacement Help-dsc00740.jpg   Basement Cinderblock Replacement Help-dsc00741.jpg   Basement Cinderblock Replacement Help-dsc00743.jpg
Old 04-01-2011, 04:41 PM   #4
Stay-at-home GC
Looks like a pretty small area, 3 or 4 blocks? The blocks don't look to bad from here. Have you considered just tuckpointing new mortar?
Old 04-01-2011, 06:03 PM   #5
above these blocks is a doorway sitting on it, and I think It's pretty simple to get access and remove these blocks. if I just put new mortar on it, It will break out with in few years later. I want to do something so it can last for few more decades. I'll try to post up the video that way it give a better view. Thanks
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Running from outside service panel into basement ksl420 Electrical 0 03-21-2011 12:30 PM
basement issues - tile, mastic, moisture pfisch Flooring 6 12-01-2008 02:35 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
Basement Window Replacement mebsdad Building & Construction 2 02-19-2007 09:10 AM
