Basement Ceilings And Code - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-28-2010, 06:57 PM   #1
Rewards Points: 410
basement ceilings and code
I'm looking for a way to get maximum height in an area of the basement .
Most will get suspended ceiling and no problems forseen but an area before the stairs has the furnace hot/cold runs right above.
Door top trim will be right in harms way .
Its a hall area that opens to the main area past the Lam beam , 5'1" x 14'
( bordered on 1 side by a Lam & the other by the theater room wall )
Would it be possible to hang 3/4 plywood with a support in the middle ( an inch away from the furnace run ),
I need to run a couple of cans in it also.
If I ran mineral wool or glass between the joist would that suffice as a fire stop?
High Gear is offline   Reply With Quote
Finishing basement, had a few questions about ductwork... Wyjeep Plumbing 12 04-27-2010 10:27 PM
Drywall - Horizontal or vertical slinku2020 Drywall & Plaster 27 04-08-2010 01:40 PM
Basement finished with Low Ceilings and no permit missy22 Remodeling 11 01-30-2009 07:20 PM
Finishing basement - low ceilings alyuka Remodeling 1 01-05-2009 09:13 PM
Raising The Ceilings propain Building & Construction 2 06-28-2006 06:33 PM
