Basement Ceiling Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-05-2010, 03:21 PM   #1
Basement ceiling insulation
This is my first post so let me know if I'm doing something wrong
I have a 1950's ranch house in Western NY. My basement is completely finished except for one room which I use as a workshop and storage. The room is 10'x10' with one window and 2 concrete exterior walls. In the winter the room gets very cold, probably low 50 degrees
Directly above that room is my son's bedroom. In the winter time, the floor to his room is freezing, probably 5-10 degrees colder than the rest of the house. The floor is hardwood with a rug. His room is well insulated with new(er) windows the only problem seems to be the floor.
I'm hoping you could help me figure out how to warm it up. I seems that my options are:
1) Insulate the ceiling of the workshop to keep his floor warmer. I could get some fiberglass batt and stuff it between the joists. It would be relatively quick and cheap, however what I've read tells me it's a bad idea and I won't see much improvement.
2) Frame and insulate the walls of the workshop. I'm not ready for the time and cost, but this seems like the best option. Maybe I could do option 1 or 3 until I'm ready??
3.) Heat the workshop. I feel like the energy costs would be pretty bad to do this and it would make the rest of my basement cold.
Has anyone else had this problem, any suggestions??
ac131 is offline   Reply With Quote
Old 10-05-2010, 05:36 PM   #2
Rewards Points: 1,910
It wouldn't take long to frame, insulate and drywall two 10 ft walls and then you'd have a warm workshop, a warm bedroom floor and lower utility bills.
If the walls are nice and flat they even make foam boards that are rabbeted to accept 1x3s. The 1x3s hold the foam in place and your drywall screws to the 1x3s. Very fast and simple. http://building.dow.com/na/en/produc...n/wallmate.htm
Old 10-05-2010, 07:42 PM   #3
Rewards Points: 40
I'd say frame and insulate the shop.Finish the walls with plywood or OSB(more durable And cheaper than drywall).Mark your studs for shelving, hanging,pegboard or whatever.If you use foam board you should cover it with a non-combustible like drywall.
daveb1 is offline   Reply With Quote
Tags
basement , insulation
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Basement Insulation raulakh Building & Construction 2 10-13-2009 12:36 AM
Insulating unfinshed basement ceiling for sound daveyd Building & Construction 38 02-02-2009 10:57 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
