Old 03-21-2006, 02:17 PM   #1
Default Basement Ceiling- Combo of Drywall and Drop ceiling?
We're in the process of finishing the basement of our new house (built 2 years ago). The builder put all the ducts and mechanicals that run along ceiling running right through the middle of the area to be finished. We'd like to use drywall on the majority of the ceiling (not an issue for about 3/4 the area) and then build a "box" around the area with the lower ducts/pipes, and put in ceiling tiles just for that area. Has anyone else done anything like this? Have any suggestions? We thought about spraying the ceiling, but decided it wouldn't look good due to the configuration of the room. My husband is very skilled at this kind of thing, but we've never tackled a ceiling before.
Any advise would be great!
H Thomas is offline   Reply With Quote
Old 03-21-2006, 03:10 PM   #2
Electrical Contractor
If there are no valves or anything that has to be gotten to after the ceiling is in, just box it and use sheetrock. your isea works also.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 03-21-2006, 03:39 PM   #3
Yes, there are mechanicals that might need to be reached later...specifically to open and close the ductwork to certain parts of the house. The ducts are two wide in most of this area.
Old 03-21-2006, 03:49 PM   #4
Remodeler
MinConst's Avatar
You will need a minimum of 3" for a drop ceiling normally I go to about 5" If you use rock all over you can pop in access panels anyplace you might need them. They are pretty cheap and you just cut a hole in the rock and pop the panel in. They can be painted or left white. You should be able to find them in your big box stores.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 03-21-2006, 03:59 PM   #5
That sounds like a good idea. Thank you!
Old 03-27-2006, 10:27 AM   #6
Default Part Two of Question
A portion of this basement ceiling has double wide ductword and diagonally crossing drain pipes. There are very limited spaces for "boxes" to be built around the utilities. Any suggestions? What is the maximum span you can go with sheetrock between the connections to the ceiling structure?
More On This Topic
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When framing the basement, we try to find the longest wall possible and square from that wall on. In this basement, this would be that wall. This is a great... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Something else you want to think about if you do decide to finish your basement in stages, is access to the plumbing and heating. If you decide to finish... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. The thickness of our insulation is going to make a difference in the R-Value. So if we have... Read More »
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. The schedule that you'll use when finishing a basement is very similar to the schedule that you'll use when finishing a home. In fact, it's almost exactly... Read More »
Whether you have one dog or several, a place in your home that is exclusively a dog space can prove convenient and practical. A dog room offers play space, kenneling during the work day or at night and an indoor kennel when house activities are not dog... Read More »
Drywall vs. drop ceiling for basement DIY4EVER Building & Construction 23 11-15-2008 09:24 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
