Old 11-03-2009, 05:15 PM   #1
Default Basement ceiling
I'm starting to finish my basement and I have some plumbing and gas lines that are surface run across the floor joists. I've measured and 1x3 strapping won't be deep enough. I am contemplating using 2x2 or 2x4 as strapping (to avoid reworking the plumbing through the joists) - is there anything drawback to using 2x4 as strapping?
bsmtreno is offline   Reply With Quote
Old 11-04-2009, 06:34 AM   #2
Cost?
Old 11-04-2009, 08:24 AM   #3
gravity always wins
2x4s will work. Done it many times.
Old 11-04-2009, 09:43 AM   #4
Default Lower ceiling versus bulk head
Thanks for the info. Another question....
I'm framing a bathroom in my basement, which is below an upper level 2-piece bthrm - convenient for plumbing but does require me to build bulkheads to accommodate the sewer run from the bthrm above. The difference between the low point of the sewer run (which will require a box ) and the rest of the ceiling is 1 to 1 1/2 inches. I'm wondering for cosmetics, should I just building the ceiling down to the lowest point and eliminate the need for an extra bulkhead. Total gross ceiling height would be approx 88inch from floor (+/- a few inches for flooring and drywall), finished height might be closer to 85 inches. Is this too low?
Old 11-05-2009, 09:40 PM   #5
gravity always wins
You're over 7 feet. There are a lot of houses that were built with 7' ceilings on the 2nd floor.
Tags
basement finishing, ceiling, strapping
More On This Topic
If you were involved in sports as a kid or have children who are involved in sports now, odds are you have a lot of trophies and ribbons floating around the house. Each one probably has it's own story of last minute shots, injury-filled seasons, and a... Read More »
Part 1 - Learn how to adjust guitar pickup height to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
Part 2 - Learn how to adjust guitar pickup height to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
Part 2 - Learn how to adjust the guitar string action to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
We are going to talk a little bit about our waste lines and our vent lines right now. The waste line being when you turn the sink on and the water that falls into the sink, where does it go, well it goes right down into this pipe here, travels down the... Read More »
Lowering Basement Ceiling artlover13060 Building & Construction 3 10-27-2009 12:51 AM
basement - steel framing / existing drop ceiling j-dude Remodeling 0 07-08-2009 11:59 AM
Drywall vs. drop ceiling for basement DIY4EVER Building & Construction 23 11-15-2008 09:24 AM
Basement Ceiling Drywall- ? When wall is concrete H Thomas Building & Construction 5 04-20-2006 11:20 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 10:27 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
