Basement Blocking - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-26-2007, 02:22 PM   #1
Basement blocking
I intend to start finishing my basement in the next couple weeks, and I'm trying to nail down all the framing details before then. The latest question I'm trying to answer is whether I need to install blocking above my exterior wall insulation. I'm planning to use the following wall construction...
  1. Adhere 3/4" Extruded Polystyrene (XPS) directly to the cured concrete wall
  2. Frame a 2x4 stud wall right up against the XPS 16" OC
  3. Put moisture retarding kraft-faced fiberglass insulation between the studs
  4. Surface the wall with 1/2" drywall
  5. The ceiling will be 1/2" dry too
My understanding is that if my framed wall was, say, 2" from the concrete wall I would need blocking above the 2" gap. My hope is that with the wall right up against the XPS, I won't need to do this. Any advice would be most appreciated! Thanks!
ksypal is offline   Reply With Quote
Old 03-26-2007, 04:43 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Do you mean wood blocking?
I am going to assume that you must mean insulation.
I will also assume that you are referring to the bay above the freezewall wall, the rim joist bay.
If this is what you are asking about, then I would say absolutely yes, you should insulate that area.
If I have this all wrong, my apologies...and ...please clarify....
- Build Well -
Old 03-26-2007, 07:53 PM   #3
I mean wood or drywall blocking. I'm afraid my description above may be somewhat lacking. Since a picture is worth 1,000 words, I'll post a link to a write-up my county did on finishing basements that provides an illustration.
http://www.fairfaxcounty.gov/dpwes/p...ts/details.pdf
Check out figure 6 on page 6 of the linked PDF. It shows the example I tried to describe of the framed wall offset from the concrete wall with insulation in between. On top of the insulation they show a fire blocking--2x or drywall or whatever.
So, going back to my original question, do you have a take on whether I'd need to put fire blocking on top of my 3/4" XPS if the framed wall is right up against the XPS?
Hopefully that's clearer now. Thanks!
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 09:55 PM
Epoxy in the basement jkrodger Flooring 1 07-20-2007 10:27 AM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 07:08 AM
Wet Basement being fixed (pics) harleysilo Remodeling 2 01-23-2007 08:09 AM
