Basement Bedroom Requirements - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-15-2010, 10:48 PM   #1
I was wonderin if a basement bedroom is required to have an egress window in it if the window is two feet outside of the door??
justwonderin is offline   Reply With Quote
Old 01-15-2010, 11:07 PM   #2
A bedroom must have a door or window IN the bedroom that leads directly outside
Window must meet certain codes & if below ground have steps leading out of the window well
Old 01-16-2010, 12:06 AM   #3
Registered User
Rewards Points: 5,266
We can't tell you enough: http://docs.google.com/viewer?a=v&q=...01YzyGnQ8v_t9g
Firemen go through that window expecting to find a person in THAT room, not the next one on the other side of that burning door: http://illowaicc.org/uploadedFiles/I...20Openings.pdf
Be safe, Gary
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 01:23 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
pre-stubbed basement bath vent needed? ameleus Plumbing 7 09-21-2008 11:26 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
