Basement Beam Replacement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-04-2010, 12:58 PM   #1
Basement Beam replacement
We live in an older home - roughly between 150 and 175 yrs old - not considered a historical structure. We have remodeled extensively in the last 10 years and recently discovered the main support beam in the basement, as well as 2 of the floor joists (trees with the bark still on them) have failed. I have a shore under it right now to support the house, but need guidance on whether to replace the beam and joists with wood (like a trilam) or steel. How do I calculate the load capacity requirements as well as spacing requirements necessary?
Current main beam is 14 ft long X 10" tall X 8" wide and is (I presume) oak. The remainder of the floor joists appear to be either oak or ?? I know driving a nail into them is near impossible.Any input would be appreciated.Thanks
middleoftheroad is offline   Reply With Quote
Old 06-04-2010, 05:23 PM   #2
Would it be practical to build a wall underneath the main beam. It would save a lot of work.
Old 06-05-2010, 06:14 AM   #3
As a last resort, yes. But that really isn't the optimal solution, and it doesn't address the broken floor joists.
Old 06-05-2010, 08:18 AM   #4
Rewards Points: 1,578
You need an engineer with an on-site visit to spec out what is needed.
bob22 is offline   Reply With Quote
Question about steel I BEAM in basement djohns10 Building & Construction 7 06-23-2012 03:55 PM
replacement basement window - how to measure? qchawkfan General DIY Discussions 9 01-20-2010 07:42 PM
Cutting a beam flange devlin1k Building & Construction 17 02-13-2009 03:24 PM
i beam in basement, notched joist component Building & Construction 1 03-18-2008 01:47 AM
Basement Window Replacement mebsdad Building & Construction 2 02-19-2007 08:10 AM
