Basement Bathroom Subfloor, Best Ideas? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-18-2008, 05:27 PM   #1
basement bathroom subfloor, best ideas?
Thanks Ron for the clarification! I am worried that vinyl on concrete, even with a vapor barrier would be too cold. I'm in Wisconsin and we get some cold winters! Wondering about the easiest subfloor I can install with moderate protection from the cold cement. I would say I have average construction skills, however I have never taken on this particular task. Any advice would be very helpful, thanks again!
Gus72 is offline   Reply With Quote
Old 01-22-2008, 02:19 PM   #2
Hi Gus72,
I bought a dimpled role of hard plastic from Lowes. The roles are 3' by 50'. The dimples are a little over 1/4" high. It allows air to circulate underneath it. The walls are slightly raised to help the flow of air. It helps to prevent the buildup of moisture on conctete. I used a sealer on the concrete floor. I covered the plastic with toungue and groove waferboard. I installed carpeting over it. The flloor does not get cold and it's comfortable to walk on. Lowe's and Home Depot sell 2' X 2' boards with the raised plastic built in. I did it my way to cut the costs down.
Dirtyron is offline   Reply With Quote
Old 01-22-2008, 02:32 PM   #3
Sorry Gus, I didn't see that you were doing a bathroom subfloor. This solution probably wouldn't work for you.
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 10:10 AM
Basement Bathroom Rough-in questions Bmbeeson Plumbing 16 12-29-2007 01:41 AM
Basement bathroom remodeling amakarevic Building & Construction 2 04-12-2007 07:59 PM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-22-2006 11:03 PM
