#1 |
Basement Bathroom - Sheetrock - Moisture Issues.
Hello
I have a finished basement, and I recently purchased the Saniflo Sanibest grinder macerating pump & toilet. I am getting ready to start summer construction by installing this bathroom, and am ordering various parts. The basement was finished years ago, and there is regular 3/4" sheetrock on the walls. The bathroom is going to have a shower, and while the bathroom will have an exhaust fan there is no window. In the corner where this bathroom with a shower will be. Should the sheetrock on the 2 existing walls and ceiling as well as the two new walls be changed to greenboard/wonderboard or hardibacker to combat the moisture that will build in there? Many more questions to come! Thanks, Michael |
#2 |
Cement board for the shower construction with a membrane or waterproofer is a must. You don't need it for the rest of the bathroom.
Josh Jaros Remodeling in The Woodlands, Texas To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Drywall contractor
With proper ventilation and proper paint applied, regular drywall will be fine...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops. |
| Display Modes | |
| Plumbing Help for New Basement Bathroom | morphers82 | Plumbing | 2 | 03-14-2009 01:17 AM |
| Basement Reno - Laundry, Bathroom | mostr | Building & Construction | 2 | 03-02-2009 10:50 PM |
| basement bathroom rough in - framing questions | twobabieslater | Building & Construction | 2 | 12-29-2008 03:56 PM |
| basement issues - tile, mastic, moisture | pfisch | Flooring | 6 | 12-01-2008 02:35 PM |
| Basement Moisture problem | jimdd | Remodeling | 1 | 07-22-2008 03:48 PM |
