Basement Bathroom - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-09-2009, 10:07 AM   #1
Basement Bathroom
I just bought a new house that has a beautiful basement perfect for finishing. The only bad thing is, I would like to install a bathroom but the house is on a well / septic system and the sewer drain exits the foundation about 3 feet off the floor.
Is there any hope of putting a toilet down there or should I just have a sink for the bar and let it be?
Thanks for any advice!
-Tom
Tommyt3782 is offline   Reply With Quote
Old 11-09-2009, 10:14 AM   #2
Your plumber can install a sewage ejector that will pump the waste 3 feet up to meet your existing drain.
Dairylander is offline   Reply With Quote
Old 11-09-2009, 11:12 AM   #3
see if you can find the top of your septic tank and how its elevation relates to your basement floor. if it is low enough you may find it cheaper to run a new line. If you can avoid a pump i always feel it's the better option
Old 11-09-2009, 12:37 PM   #4
I have installed these, and they work great.http://www.saniflo.com/
If you do it yourself, the materials are around $800.
CustomBuild is offline   Reply With Quote
Old 11-09-2009, 01:08 PM   #5
Wow that sounds like a good idea. That part I might have the plumber do but i'm glad that it's possible.
I will check into the hight of the septic though, a drain line wouldn't be too much work either.
Thanks for the info!
Completing a roughed in basement bathroom Bob in St. Louis Plumbing 8 11-18-2011 01:12 PM
basement bathroom JED5000 Plumbing 8 05-02-2009 04:34 AM
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 01:17 AM
Renovating basement bathroom???? Oldyota Plumbing 1 01-10-2009 08:51 AM
re-adding a basement bathroom jimmyfloyd Plumbing 4 11-10-2008 07:31 PM
