01-26-2013, 10:33 AM
#1
Basement Bath No Vapor Barrier
This bath was started without putting in a vapor barrier between blocks and stud walls. Brother says its fine, I say its not. Its a dry basement and block walls have 3 coats of UGL Drylock. Only 2 walls are exterior (under ground), the other 2 are just 2x4 stud walls in open basement. Its my understanding that a vapor barrier should have been put in between the stud walls and blocks, then insulated. No insulation behind shower either. Brother says nothing goes behind shower, says we insulate other stud walls and put vapor barrier between drywall and studs. I think he is wrong.
How should this have been done and what are our options short of convincing him to tear it all out and start over?
01-26-2013, 01:13 PM
#2
i guess the first one never went, so.... first, where is this? i would absolutely install up to 3" of rigid foam in your exterior walls, leaving it loose enough to get the tip of a spray foam can in to seal it. no need for insulation in interior walls, unless noise is a concern. "wall is dry"; have you taped visqueen to the wall and let it sit a few days? water does not wick in buckets, so it can evaporate as fast as it wicks. you are probably ok w/ the drylok on. what appliances are going in? shower? tub? tile? etc. instead of relying on poly between studs and drywall, it may be better to use cementisous (however you spell that) boards, sealed. btw: pipes in exterior walls are to be within 1/3 of the way through the insulation; you may have a problem there, assuming the outside of the blocks does not have a ton of rigid foam and your soil gets cold.
01-26-2013, 01:21 PM
#3
gawd-save-us from brother-in-laws
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
01-26-2013, 04:41 PM
#4
that is spelled "bother-in-law"
01-26-2013, 08:02 PM
#5
This is very much a local code issue. How are we to know what's legal where you live?
01-27-2013, 03:09 PM
#6
Moderator
Good point, WHERE do you and your brother live? Or where is the house?
Gary
Clothes taking longer to dry?
01-27-2013, 06:01 PM
#7
This is in northwest Alabama
01-27-2013, 08:47 PM
#8
Moderator
You are under the 2006 IECC; http://www.reedconstructiondata.com/...codes/alabama/
No vapor retarder or barrier is required below-grade; http://publicecodes.cyberregs.com/ic...2_4_par027.htm
No insulation on basement walls is required per code; http://publicecodes.cyberregs.com/ic...2_4_par004.htm
However; with your Jan, Feb, and Dec. lows averaging 34*F (and your concrete wall above-grade +6" below), you need to keep the basement relative humidity below 27% with 70*F room temperature for no condensation there. With 1" XPS (R-5), the dew point is 33% RH in basement, for that small area during that cold weather temperature and below. Pretty mild.
Again, don't use a vapor barrier plastic or vapor retarder faced-insulation; http://www.buildingscience.com/docum...commendations/
Gary
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
