Basement Apt Floor Plan And Its Worth - Building & Construction - DIY Chatroom Home Improvement Forum
Closed Thread
Old 01-15-2012, 08:26 AM   #1
Basement apt floor plan and its worth
From a basement for storage, to a 1 bedroom, with a living room, and a bathroom laundry room combo + 1 new exterior exit. Can anyone estimate how much this should add to the value of the home?
styleten is offline
Old 01-15-2012, 08:31 AM   #2
Rewards Points: 6,652
A penny, a gazillion bucks. Really there is no way to know. This is why you should work with a Realtor and let them tell you. Are there other homes in your neighborhood with an apartment in the basement? Also keep in mind that since you are placing a secondary living space in the basement, there is more than just slapping it together and being done. Most areas require separate hvac for that space, along with some other factors. Also may require you to install some type of fire suppression system and lighting for pathway to the escape route.
gregzoll is offline
Old 01-15-2012, 08:42 AM   #3
Rewards Points: 150
Not as much as your thinking probably. As stated above there is alot more that goes into getting a second occupancy permit than slapping up some walls. After you factor the initial cost the return will likely be small, plus someone will be living in your basement...
OhioHomeDoctor is offline
Old 01-15-2012, 08:42 AM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 666
Send a message via Skype™ to AndyGump
$23,687.35.
A price direct from my bum.
Andy.
AndyGump is offline
Old 01-15-2012, 09:00 AM   #5
DIY staff
Rewards Points: 7,174
Andy has spoken---we now have the answer---
oh'mike is offline
Old 01-15-2012, 09:04 AM   #6
AndyGump's Avatar
Rewards Points: 666
Finally...
Recognition.
Andy.
AndyGump is offline
Old 01-15-2012, 09:15 AM   #7
There you go Andy.....its about time you get the respect that you deserve
creeper is offline
The Following User Says Thank You to creeper For This Useful Post:
oh'mike (01-15-2012)
Old 01-15-2012, 10:38 AM   #8
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
I know you're not asking how much to build it, but similar issues apply.
"How much will it cost?" Asking for price estimates here.
Blondesense is offline
Old 01-15-2012, 10:42 AM   #9
DIY staff
Blondsense--You want to be a moderator? You have the spirit---Some times I forget to be all upright and proper.
oh'mike is offline
Old 01-15-2012, 10:44 AM   #10
Yeah, but we like you that way
creeper is offline
Old 01-15-2012, 11:04 AM   #11
Stuck in the 70's
Thanks, but no thanks!
I spend way too much time on this site as it is. I should be cleaning out my fireplace insert right now. Just plain procrastinating.
Old 01-15-2012, 11:36 AM   #12
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by styleten View Post
.... Can anyone estimate how much this should add to the value of the home?....
Even though the question is one of "how much increased value?", the principles below still hold true, in addition to the added factor of: greatly varying local property value scales (they are different everywhere).
Thank you for posting your question on the DIY Chatroom.
Questions involving pricing, such as – “How Much” certain projects cost (i.e. - certain repairs, renovations, square-footage pricing, an addition, a decks, etc., etc.) – cannot be properly answered simply by information posted on an internet forum (regardless of how much information is supplied in a particular post). There are many, many variables, which also involve site visit(s), existing conditions, final designs, local-rates, material preferences, etc.
Pricing for materials may be determined at your local supplier(s). Prices for subcontracted work are best determined by getting legitimate local contractors to submit written estimates (3 are suggested) and always checking references.
The industry generally suggests allowing a minimum of 20% buffer, over the assumed budget, for incidentals, unexpected points, material overages, etc.
We encourage you to continue to post other DIY related questions on this site.
- Build Well -
AtlanticWBConst. is offline
Closed Thread
