Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-22-2012, 01:25 PM   #1
basement
Should I be concerned about frost forming on inside of cement basement walls (in the Corners) that are above ground level ? This frost occured at -20c. and colder. Now that it's warmer it's damp.
I was also wondering if it is code now to put poly on the bare cement walls before insulating with fibreglass batts? We live in Saskatchewan Canada.
Thankyou Verla
verla is offline   Reply With Quote
Old 02-22-2012, 06:58 PM   #2
Rewards Points: 4,526
i would be concerned as there's probably a high humidity problem inside the bsmt,,, warm air contains higher water vapor than cold air,,, when the damp air hits the cold surface, condensation forms,,, vapor barrier then insulation will resolve the issue,,, rather than f/g, i'd use foam panels glued to the wall w/taped joints,,, its not normal that you'd need a dehumidifier in the winter but stranger things occur
Basement sewer smell jturk1000 Plumbing 1 09-20-2011 01:59 PM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
