Baseboards With Logix Blocks For Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2008, 09:31 AM   #1
Baseboards with Logix blocks for basement
Hi there,
I built my basement using the Logix blocks and am in the process of finishing it. I'm just laying the flooring and will then need to do the baseboards. How do I fasten the baseboards to the drywall when there is no wood behind the drywall to fasten to? Do I try to hit the plastic strips that are embedded in the styrofoam (that would take pretty long nails)? Do I glue it on?
Thanks,
Wes
ReluctantFarmer is offline   Reply With Quote
Old 07-22-2008, 09:57 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
Use some quality construction adhesive, then double nail the trim at an angle driving the trim tight to the drywall where the trim needs to be pushed tight to the wall until the glue dries. then use painters caulk along the top for extra holding power and to fill any voids. Good luck BOB
Reattaching baseboards? Joony Flooring 7 07-06-2008 08:11 AM
AAC or standard CMU blocks oar Building & Construction 3 06-10-2008 06:43 AM
Click lock floors under baseboards ? bcarwell Flooring 4 03-30-2008 11:03 PM
HELP: Bleeding Baseboards Roztom1 HVAC 2 10-11-2007 03:10 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
