Baseboard - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-16-2008, 03:26 PM   #1
Baseboard
We have a 1951 house with plaster walls. I put new carpet in the livingroom and removed all the old baseboard. It was just bad, scratched up by the previous owners dog, and just generally nasty. Anyways, what is the best way to attach new baseboard to the walls. Nails, Glue or screws? My last house had drywall so that wasnt too hard. If it is nails is there certian ones I should use? Thank you for any info.
Bigdaddyt is offline   Reply With Quote
Old 11-16-2008, 03:34 PM   #2
the Musigician
DangerMouse's Avatar
most use finishing nails sunk below surface and filled/sanded to paint. i'd hate to be the next guy that laid flooring if you used glue! lol
DM
Old 11-16-2008, 10:06 PM   #3
All trades carpenter
Most houses that I have run into with old plaster walls had a wood board at the bottom of the wall about 2" tall so you could nail the baseboard to it. This board would not be covered with plaster but be painted the same color as the wall. Someone on the site might chime in with a name for that board. If that board exists in you house you should be able to nail the baseboard to it just fine.
CrpntrFrk is offline   Reply With Quote
Painting baseboard tips/tricks mahjohn Interior Decorating 15 10-29-2011 12:54 PM
Tile baseboard with carpet? bpak04 Flooring 2 11-03-2008 01:28 PM
Replaceing Baseboard to curvy wall problem agfrag Carpentry 13 08-29-2008 04:40 PM
convert from gas boiler to electric baseboard marks5894 HVAC 1 10-21-2007 01:22 PM
Need help with finding very wide baseboard Showbiz Carpentry 2 05-28-2007 08:52 AM
