Barn Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-07-2010, 02:27 PM   #1
barn insulation
Looking to insulate my barn with rigid styrofoam board insulation.... Do I need vapor barrier with this as I would if I used regular pink insulation?
fjacky is offline   Reply With Quote
Old 11-07-2010, 05:05 PM   #2
if you are diligent with your seam sealing, you should not need a vapor barrier. but you will have to hit any voids with foam and tape all seams, cracks, etc...
1910NE is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 02:33 PM
Barn insulation fjacky Roofing/Siding 0 11-05-2010 10:29 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Barn insulation fjacky Building & Construction 2 10-06-2010 09:40 PM
