Barn Door Hardware Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 10:55 AM   #1
Rewards Points: 198
barn door hardware help
can someone help me track down the hardware this door is using?
i've recently purchased and they are just simply too heavy duty for a small bathroom door. aside from being too heavy duty, i find that the rail hanger allows the door to swing back and forth thus scratching up the wall. i'm looking for something that is more still and solid such that the door does not rest against the bottom of the drywall.
http://www.hardwareandtools.com/Stan...r-0585133.html
http://www.hardwareandtools.com/Mint...e-5902440.html
tx much.
vote4Pedro is offline   Reply With Quote
Old 02-04-2012, 11:09 AM   #2
Rewards Points: 12,802
Why not just replace that with a real reguler door instead of that nasty ugly thing?
Your missing the bottom door guide to stop it from swinging.
Old 02-04-2012, 11:17 AM   #3
joed's Avatar
Rewards Points: 11,534
Looks possibly like pocket door hardware. You need a U shaped guide on the floor to keep the door from swinging.
Check here.
http://www.hangingdoorhardware.com/p...cketguides.htm
Old 02-04-2012, 11:36 AM   #4
Google Flush door hardware, not pocket door there no the same hardware at all.
Old 02-04-2012, 11:41 AM   #5
Rewards Points: 198
it's a small hall way with 2 door opening already. adding a 3rd would just kill the entire hallway.
Old 02-04-2012, 11:56 AM   #6
Rewards Points: 198
not too much information on flush door hardware. is the roller a standard size? i guess i'm okay with a wider rail but i just don't want the door to swing. will this work?
Old 02-04-2012, 12:01 PM   #7
Any box store will have by pass door hardware made of plastic. Buy one and just cut off part of it. There made to steady two doors and you only need 1/2 the bracket.
A single roller will just stop it from hitting the wall, the bypass guide will stop it from swinging in both directions.
another barn wiring question wendell2 Electrical 10 05-29-2011 09:04 PM
My old barn roof collapsed starchild General DIY Discussions 5 02-08-2011 02:15 PM
Grounding Panel at Barn EWW Electrical 4 12-23-2010 12:15 PM
How much power can i give my new barn? DonQ2010 Electrical 16 09-08-2010 10:23 AM
I've lost power at my barn Jim Owens Electrical 11 10-11-2008 11:58 PM
