Barge Rafter Connection To Ridge - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-22-2011, 10:18 PM   #1
barge rafter connection to ridge
i have a small porch roof framed minus 2X sub fascia and 2X4 barge rafters.
i'm wondering how to go about laying out the cuts for the barge rafters so that they butt against each other to cover the end grain of the ridge? if i use my rise/run and don't factor in the ridge thickness, they will leave little triangles of ridge exposed and the plywood won't plane in properly.
only way i can see making it work is to raise them up past the ridge and then cut the points off the barges flush with the top of the ridge.
or, if it's easier, i can cut the ridge flush with verge rafter, and install lookouts. but i see this option taking more time.
overhang is only 6" so i don't see a problem with only ridge and sub-fascia supporting the barge.
thanks.
wombosi is offline   Reply With Quote
Old 05-22-2011, 11:28 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 208
The barge rafter points will stick up above the ridge board if you nail the barge rafter to the end of the ridge. Are you not going to run a fascia board over the barge rafter?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 05-23-2011, 08:15 AM   #3
yes, i am using a fascia board over the barge.
the problem is the eaves are already cut to the right overhand, but i accidentally cut the ridge 1 1/2" short (otherwise i would just butt the rafters to each side of the ridge and be done with it).
looks like i'm doing lookouts...
Old 05-23-2011, 11:33 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 208
This may not be the way to do it but I would block on each side of the ridge and nail the barge to the blocks. The decking should give some support no wider than the overhang is.
Jim
Rotted Lookout Beam Supporting Barge Rafter rwbil Building & Construction 1 08-15-2010 12:40 PM
Ridge and Rafter size Joe1. Building & Construction 2 08-11-2010 01:08 PM
Ridge beam end to end connection..sagging? windowguy Building & Construction 5 01-20-2010 12:31 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 06:47 PM
Rafter to ridge beam height JESSBRA2 Building & Construction 1 10-20-2008 04:34 PM
