Closed Thread
Old 10-03-2012, 11:55 AM   #1
bml.4517's Avatar
Band/Rim Joist - Water Damage...Repair?
As you can see from the picture there is a very small section of damaged Rim Joist. The chimney, which is behind it, had leaked from the flashing on the roof (wasnt properly flashed or cemented).
What do you guys recommend on this situation?
Also, some of the subfloor is rotten and damaged so I will be removing the old and patching the gaps with new OSB.
Band/Rim Joist - Water Damage...Repair?-forumrunner_20121003_114933.jpg
bml.4517 is offline
Old 10-03-2012, 12:01 PM   #2
bml.4517's Avatar
Here are the upper floor pictures.
This is a two level house with a small attic
- basement
- main level apartment style house
Band/Rim Joist - Water Damage...Repair?-forumrunner_20121003_115855.jpg   Band/Rim Joist - Water Damage...Repair?-forumrunner_20121003_115937.jpg   Band/Rim Joist - Water Damage...Repair?-forumrunner_20121003_120009.jpg
bml.4517 is offline
Old 10-03-2012, 12:06 PM   #3
Can you get at it from the other side?
If not then once you have stopped the leak and dry it up put blocks between the joists and in each space beside this one. This will provide lateral support for the ends of the joist.
mae-ling is offline
Old 10-03-2012, 12:07 PM   #4
Also that last pics looks like you have a rafter landing on a double top plate with no stud below it? And the one beside it too?
mae-ling is offline
Old 10-03-2012, 01:38 PM   #5
based on the picture, i am going guess that op removed those studs...
as far as the rot goes, it really doesn't look too bad. i would apply wood preservatives in the area and install blockings as mae-ling stated (but i wonder why there is a scab 2x4 attached to your joist?)
allthumbsdiy is offline
Old 10-03-2012, 05:34 PM   #6
bml.4517's Avatar
Guessing is never professional. The two 2x4s werent even there under the joists ur looking at. Strike.
Address the problem at hand so you wont be wrong in assumptions...
The problem has been fixed from the start of the leak...which is the roof. I replaced the rotten osb after removing certain shingles. I will be redoing the flashing tomorrow lord willing.
Thread closed.
bml.4517 is offline
Old 10-03-2012, 05:47 PM   #7
Wow.
mae-ling is offline
Old 10-03-2012, 06:12 PM   #8
GBrackins's Avatar
you said it mae-ling!!!!!
I feel like I got hit with a brick and didn't even post anything .... I'm gonna have to do much better in the future when providing my free opinions for people that willingly come here
thumbs, here's you a bandaid
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is online now
Closed Thread
Apartment water leak - questions haris General Discussion 2 03-23-2011 08:26 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
basement wall waterproofing Jenbarkel Building & Construction 9 08-30-2010 06:37 PM
Subfloor repair Dave321 Flooring 3 09-16-2009 09:59 PM
