Balloon Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-26-2009, 01:13 PM   #1
Balloon Framing
Two questions:
1) The ledger for the second floor: Should the ledger be notched into the upright studs or not?
2) Would it be sensible to build the wall standing or build it on the ground then try and lift it? The total wall will be 14' high be 40' wide.
Thanks in advance.
kemp is offline   Reply With Quote
Old 06-26-2009, 01:54 PM   #2
Framing Contractor
Originally Posted by kemp View Post
Two questions:
Thanks in advance.
Why are you balloon framing it? What is the first floor height and height of the floor joists, and what type of roof is sitting on the second floor wall? Are the plans drawn by an Architect?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 06-26-2009, 02:07 PM   #3
Remodeler
adpanko's Avatar
Rewards Points: 150
My 1890's house had balloon framing where the ledger was notched into the studs.
I'm not a framer, but is balloon framing allowed nowadays? I assume you need to fireblock the hell out of it if it is, but I wouldn't think it is allowed over platform framing. Is it better, or required, in certain framing circumstances?
adpanko is offline   Reply With Quote
Old 06-26-2009, 02:08 PM   #4
I'm getting some preliminary drawings ready for a discussion with a Structural Engineer. I realize they could simply tell me the answer about the ledger for the second floor (and I am sure they will). But, I have learned over the years that it is best to cut down on the number of "distractions" when talking to people.
As for the question about the wall being built in place, well, that is actually a question for later. I just thought I would kill to birds with one stone.
The walls are balloon framed because the house is a cape cod style. The wall studs need to run all the way from the foundation to the top plate under the roof. The roof is pitched. Without solid studs, the only thing keeping the second floor walls from spreading is the collar tie. The ceiling height for both floors is approx 8-1/2' and the floor joists are 2 x 12" for a 14' span.
Thanks for you input.
Old 06-26-2009, 02:22 PM   #5
Registered User
Rewards Points: 4,924
You are attempting something that requires a lot of detail and knowledge of the building code. These codes are written to keep you safe, which is why professionals state the engineering required. They are called Structural Engineers. The details of your framing should be on paper, checked by a S.E., and submitted to your local Building Department for approval.
Your house is listed on the County's record, number of bedrooms, bathrooms, floor square footage, etc. Any changes made should be recorded with a permit so you won't have to rip out all your hard work later, if you ever sell. Notify your Homeowners Insurance agent, so you will be covered for theft and mostly fire. Be safe, G
Old 06-26-2009, 02:37 PM   #6
I guess you missed that part of my last post. I am not trying to bypass anyone.
This is a very complex, partial re-build. I want to show the Structural Engineer what I have in mind and how I believe it can be done. I do not want to just tell them what I want and let them figure it out. That kind of approach is expensive.
Do I need to be this annal about some sketches -- No, I don't. Am I? -- Yes, yes I am.
Old 06-26-2009, 02:56 PM   #7
Framing Contractor
Why do they need to run all the way to the roof?
This type of framing will hold the walls in if they are set at the proper height. No need to balloon frame.
Is that 8'6" for each floor, or 8' 1/2" for each floor? Let's say it's 8' 1/2" for both first and second floor ceiling height. That equals 16' 1" plus 11-1/2" floor joists and 3/4" sub-floor. You have a total ceiling height from first floor deck to second floor top plate of 17' 1/2".
How do you get 14'?
Joe Carola
Old 06-26-2009, 03:10 PM   #8
Joe Carola: The second floor walls are approx 5' high. The roof provides the remaining wall up to the collar tie at 8' 6" (approx). If the studs do not go all the way up from the foundation, the only thing keeping the walls from spreading on the second floor is the collar tie.
It is my understanding that platform framing would require building a 5' high wall with no resistance (except the collar tie). In that case, the roof would flatten along with the upstairs walls and the entire house would collapse.
Appreciate your feedback.
Old 06-26-2009, 03:18 PM   #9
Framing Contractor
The Engineer will determine that if the collar tie at 8'6" is set at the right height, the walls will not move. This type of framing is done every day. Collar ties at the correct height, walls will not move. Balloon framing is your last resort. If the Engineer says that the collar ties at 8'6" isn't the correct height, he can add a structural ridge. You have options here. I've never seen a Cape Cod house balloon frame like you're describing.
Joe Carola
Old 06-26-2009, 03:36 PM   #10
Thanks everyone. Appreciate your comments and your efforts.
I will ultimately let the Engineer make the call, of course. But, I personally have been leaning toward balloon framing for this project because I have seen plenty of sagged roofs and spreading walls over the years -- one stories at that. This house is located near a lake and the winds can get pretty fierce.
Joe Carola. I am sure you are correct about platform framing being suitable for this project. But, ceiling heights play a big part here and so does wind shear. The stronger the finished structure and the more flexibility to keep the ceilings at the desired height the better.
I never thought such a simple question would become so involved. All I want to know is if the ledger should be notched or not. And, if any one with experience has ideas about building the wall standing or on the ground.
Old 06-26-2009, 03:54 PM   #11
Framing Contractor
Probably because they weren't framed right.
And when the collar ties are set at the correct height they are structural and will hold your walls in and ridge up no matter where your from.
That's because it's not such as simple as question as you think it is. Your asking to frame a balloon framed wall for no reason other than just because you think it's the right way without considering any other thoughts. Framing the way you want isn't normal. So you will be questioned, that's all. Why bolt or notch a ledger and fire block and hang joists off joists hangers for no reason if you don't have too? All I;m saying is you have another option.
Joe Carola
Old 06-26-2009, 04:13 PM   #12
Thanks Joe Carola. You are good, no doubt.
I like to think I am open to ideas. This is simply the direction I picked because it is the one that makes me most comfortable in regards to wind shear and spreading. If the Engineer says I am nuts, I will of course have to agree with yourself and them.
Your comments, knowledge and experience are appreciated.
Old 06-26-2009, 10:19 PM   #13
we just did a home and we did a partial balloon frame with a ceiling height of 16' at its peak in the kitchen. It really stiffens up a wall of that height. Ive built them the other way as well and the wall is not as rigid especially above the 8' foot mark ( standard 92 5/8" studs ).
II Weeks is offline   Reply With Quote
Old 06-26-2009, 10:40 PM   #14
My house is a Cape
Back was dormered, 2nd floor walls ended up at ~6'
This was platform framed
That was 5' years ago & nothing has moved
Ceiling rafters are at about 7' 6" & the ceiling the slopes down to the 6'
Celing joists collar ties both keep the walls from spreading
Collar ties required every 3rd rafter, I put them on every rafter
Old 06-27-2009, 06:54 AM   #15
Theres no need for balloon framing if theres a floor between but for outside walls with heights over lets say 14' and no other structure to help support than balloon framing helps stiffen the wall IMO. Ive seen it built both ways and saw first hand the difference.
Heres an example of what I saw. This is an outside wall with cathederal ceilings. Ceiling hieght, collar ties were at 4' feet below the ridge.
They doubled up the king studs on both sides of the door and window. The rest of the framing on the wall was done normally.It was a solid wall.
framing material estimate maydoug Building & Construction 38 06-12-2009 02:32 PM
How do I find a framing contractor in Rhode Island christy123 Building & Construction 2 10-25-2006 11:29 PM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 10:27 PM
Wood Framing Getting Wet? stagger19 Carpentry 2 05-10-2006 09:37 AM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
