Balcony Supports - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 05:51 PM   #1
balcony supports
once again a simple project has turned into a nightmare, i am currently working on repainting my 4 columns out front of my 2 story house, among some of the items i needed to fix i noticed i have alot of wood rot so after cleaning everything up i focused on getting as much of the rotted wood out so i can use the hardener and 2 pt wood filler to fix, here lies the problem the more i scraped and cleaned out the rotted wood the larger it became until soon it was obvious i was going to have to replace entire sections of wood, thinking that the 2x8's were just covering up the center support for the upstairs balcony i figured i would cut off the bottom section and replace with a new pc but once it was off i noticed A: all 4 sides were rotted B:there is no center support. so i stopped and now i am looking for somekind of stand to support my balcony, ahern is not much help since i dont know what they are called, so heres my question what is the name of a support i can use for my balcony and is my thought of replacing entire pieces with new wood then filling hole with concrete to prevent water from pooling up in hole (like i had found) the best route to take i am already at a point where i think i can do this on my own but anything more technical and i will have to call in the calvary thanks in advance for any help provided
Thanatos is offline   Reply With Quote
removing roof supports in attic, installing a room denemante Building & Construction 4 01-24-2011 09:51 PM
balcony delema onthelevel Carpentry 2 09-13-2008 11:53 AM
Moving Header Supports Star Building & Construction 3 09-25-2005 01:50 AM
45 Degree balcony supports rickr01 Building & Construction 5 09-12-2005 12:10 PM
wooden balcony in living room Lorac Building & Construction 1 07-24-2004 04:33 PM
