Baffle Spacing In Eaves - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-11-2008, 02:25 PM   #1
the Musigician
DangerMouse's Avatar
Question
baffle spacing in eaves
hi guys!
how far into my 2 ft. eaves do i extend the plastic or styrofoam baffles?
just to the edge of the outside wall? a few inches beyond? is there code for this? and which is better/easier to work with/cheaper?
tnkx!
DM
Old 08-11-2008, 02:49 PM   #2
Registered User
Termite's Avatar
Wherever you're going to have insulation touching roof sheathing of filling the eave a little, you should put a baffle. The more the merrier.
Old 08-11-2008, 03:48 PM   #3
the Musigician
that's not what i mean, i know that.... the things are 4 ft. log or so, how far OUTSIDE the house should they extend into the soffit area?
sorry, my terminology is goofy... long day.
tnkx!
DM
Old 08-11-2008, 03:59 PM   #4
RippySkippy's Avatar
Just beyond the vertical plane of the exterior wall. If you have energy heals on your trusses and have a steep roof pitch, it MAY be necessary to install a baffle below the trough if you're blowing in Cellulose.
better/easier to work with/cheaper? Check your local supplies...I used the styrofoam version, stapled to the bottom of the sheathing, something similar to these. If this is new construction, I'd put them every rafter bay, no need to skimp here....if you do nothing but problems in the future.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 08-11-2008, 07:15 PM   #5
the Musigician
thank you rippyskippy, that link had the answer--->NEW CONSTRUCTION: Place CertiVents on the underside of the roof sheathing between framing members and slide down into soffit area 6".<----just wanted to be sure.
DM
Building overhang eaves and soffits on old house justdon Remodeling 6 07-04-2008 09:59 AM
Conduit Spacing / Separation smitty286 Electrical 3 04-08-2008 10:11 AM
spindle spacing jibber Carpentry 5 02-18-2007 08:30 PM
