Bad Water Damage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-11-2012, 04:19 PM   #1
bad water damage
I bought a house that needed a'lot of work what i wanted. The house was built in 1900. I have completely remodeled the downstairs but the kitchen. The kitchen was is a two-story addition added some time later. When i bought the house i knew the roof was leaking above the addition and repaired, it after buying. The problem is the leak was much worse than i had thought. So i gutted the kitchen and found the studs and outside sheathing and sill plate completely rotted. The bad section is about six feet from corner on each wall. i believe it is a balloon style framing. The studs are full length from sill to roof, and the corner stud is now resting on the foundation. How do i replace this without the thing falling over ?
jixxer_600 is offline   Reply With Quote
Water damage. How bad can it be? alexin General DIY Discussions 3 08-23-2010 01:53 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
