Bad Lumber For Deck Issue - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-29-2012, 06:38 AM   #16
Not so new
12penny's Avatar
Rewards Points: 520
I go and get my 5/4 decking and lay it down on the deck, its not flush! So I string a line across the top of the joists, nothing is level. So I start to measure the joists and NONE of them are the same size, they range from 7-1/8" to 7-1/2".
Side note, we are just building this sell the house next spring, so we are not looking for perfect, we are just look for meets code and is safe and looks respectable.
I see it off as much as 1/4". I dont think you'll see 3/8" after its decked but, I have used a power plane in the past to take off high spots. Allways seemed easier than taking structure apart.
12penny is offline   Reply With Quote
Old 09-29-2012, 11:20 AM   #17
AHH, SPANS!!!
Rewards Points: 1,166
rule of thumb for framing treated lumber, make the tops of the joists the same where the decking lays. Cut, notch, add any needed variances to the underside of the structure.
To fix your problem try and pull the hanger nails with a cats claw and reinstall flush with the top of the ledger-band board. If the cats claw does not work, get a 12" metal sawz all blade and a sawz all and cut the joists and hangers free and re attach flush to the top. You can even notch some out of the underside of the joists to sit down into the hanger better and flush out the tops...
hand drive is offline   Reply With Quote
Old 09-30-2012, 06:40 AM   #18
After reading this thread, I'm curious. What is the best way to set your joists? Set a couple level lines across and adjust each one individually? What about the shrinkage? Can one board shrink much more than another?
MisterSteve is offline   Reply With Quote
Old 09-30-2012, 08:18 AM   #19
AHH, SPANS!!!
Not a lot can be done about board shrinkage, except leaving lumber at the job a few weeks before framing with it to get it acclimated but that does not always work. It is best to figure out the used side and make all joists flush with the useable side.
For a deck with the top side being used(decking) only, the best way is to build the floor with the joists flush along the top edge of the floor frame perimeter. Toe nail the joists into place, after it is framed add on the joist hangers. If you are sitting the joists onto a beam notch the joists at the beam to accommodate even sizes throughout or rip the entire joist down to make them all the same. With joist hangers, it does not matter if the joists have a 1/2" difference between one another because the difference ends up beneath the useable surface (topside).
Old 09-30-2012, 09:28 AM   #20
robertcdf's Avatar
Want to know the BEST way?
Use a steel frame system, the benefits far outweigh any downside, you don't deal with any of these issues.
robertcdf is offline   Reply With Quote
Old 09-30-2012, 11:38 AM   #21
Sorry to hear about you problems. Have you contacted your supplier about the material? Many times they will contact their manufacturer and they will replace the material and pay you money for labor to replace. I have had this type of problem before and my supplier made it right. The material with 1/2" of variance is not to manufacturing spec's. Your supplier mixed your material from two different bunks or from two different mill runs.
Rocket98 is offline   Reply With Quote
Old 09-30-2012, 11:48 AM   #22
AHH, SPANS!!!
1/2" in treated is standard imo, that stuff is all over the place...
Sistering floor joists for attic renovation - lumber size/engineered/LVL etc. BeanAcres Building & Construction 6 05-28-2012 12:05 AM
how to reduce mositure issue on basement? diy001 Building & Construction 0 10-28-2011 12:44 PM
Perplexing AC issue AvalonGirl HVAC 22 08-17-2011 06:49 PM
Ceiling issue wooten General DIY Discussions 5 06-06-2011 07:20 PM
Flood/Drainage Issue On Garage Man Door altc81 Building & Construction 2 04-17-2011 08:19 AM
