Is It A Bad Idea To Leave An Air Compressor Under Pressure ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-13-2008, 09:22 AM   #1
Rewards Points: 1,062
Question
is it a bad idea to leave an air compressor under pressure ?
or should i release through the valve when i am done ? like a couple of hrs at a time.
Old 06-13-2008, 09:49 AM   #2
Generally, no. But it depends on the machine
It is designed to hold pressure you know. :P
However, long term storage is different and depends on the specifics of the machine.
(I'm not an air compressor mechanic, dealer, or vendor. Just another diy'er and this is just my opinion)
ChrisCM is offline   Reply With Quote
Old 06-13-2008, 10:15 AM   #3
47_47's Avatar
Rewards Points: 58
I drain mine ~weekly, but leave it full, unplugged and the regulator backed off. Mine is stored in the basement. If storing outside (unconditioned space) I store it empty with the drain valve open.
47_47 is offline   Reply With Quote
Old 06-13-2008, 10:16 AM   #4
Registered User
Termite's Avatar
It is good practice to drain them between uses, or at least at fairly regular intervals. The pressure isn't such an issue, they're made to take it. The reason is that you need to evacuate the moisture (in the air) from the tank. On even the driest days, I usually get a tablespoon of water from my compressor, which has a drain valve in the bottom of the tank. Draining at the regulator won't deal with all the moisture. Of course, the moisture will degrade the tank faster. Either way, you'll still get years of use, but a properly maintained tank will outlast a constantly wet tank every time.
Old 06-13-2008, 02:35 PM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
Make sure you unhook any rubber air hoses if you let the compressor charged.
Water pressure and temperature billvasko Plumbing 9 06-02-2008 09:23 AM
fittings and pipes sizes.. effect on pressure? cgerikh Plumbing 3 05-19-2008 10:37 AM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
Pressure Fluctuation with well water beertestr Plumbing 5 10-03-2007 09:18 AM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 09:04 PM
