Bad Drywall Job, What Should I Do? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-08-2008, 10:11 PM   #1
Bad Drywall Job, what should I do?
I am completly redoing a house (built in the 30's) and I have a local guy doing the work for that I know nothing about (IE Drywall). We have gutted the place and redid the electricity as well as the pluming.
After the drywall was put up I was a little worried about a few spots. He told me that some of the trusses in the ceiling were saging so it was hard to get everything lined up.
Before we primered I didn't notice as many bad spots as I do now (see the pictures below)
http://localhostr.com/files/8d8007/CIMG3192.JPG
http://localhostr.com/files/c18887/CIMG3194.JPG
http://localhostr.com/files/aa3e1b/CIMG3195.JPG
http://localhostr.com/files/f9d939/CIMG3196.JPG
http://localhostr.com/files/98c5b3/CIMG3198.JPG
I have brought these up to the guy and he said he will work on the bad ones but he doesn't think he can fix the others.
Is there a way for him to fix all of the problem spots?
fowen is offline   Reply With Quote
Old 04-08-2008, 10:48 PM   #2
Rewards Points: 5,336
The pictures are a little on the dark side and a little out of focus. I can't really tell what sort of job it is.
Ron
Old 04-09-2008, 07:05 AM   #3
When is fishing season?
CowboyAndy's Avatar
If things were sagging, then you should have used furring strips and shimmed them out level. From the first pic, it more looks like a bad tape joint...
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 04-10-2008, 02:33 PM   #4
If your drywaller was an experience drywaller he should have suggested a framer to come in and fix the problem. Drywallers depend on their reputation to continue receiving work. From the looks of the ceiling their you used half in. board to hand the ceiling with. If it is truely the trusses that are sagging I personally would have done one of two things. One referr you to a framer to either fur the trusses to be level or use a chinese jack to level them out. Two I would have definetly suggested using 5/8 board which does not conform as easily to the contour of the framing. The problem can be fixed by doing it all over again and if the drywaller has any kind of guarantee on his work I would definitely hit him up on it.
Nater
nater77 is offline   Reply With Quote
Old 04-10-2008, 06:14 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Just another reason, why it is good to install strapping onto truss chords, prior to sheetrock.
- Build Well -
Old 04-10-2008, 06:22 PM   #6
I think your drywall guy is just trying to make excuses. The problem spots just look like bad tape joints. Tell him to get someone in there that can float out the joints.
jerryh3 is offline   Reply With Quote
Old 04-10-2008, 09:44 PM   #7
im guessing the guy you hired was the lowest bid.sagging truss are no excuss. even in new construction truss go up and down. looks like bad butt joints.
a good drywaller can float those out , take alittle work but not rocket science.
jason h is offline   Reply With Quote
Cost to Drywall hang/finish...please read, good explanation Firehawk734 Remodeling 64 12-12-2014 04:15 PM
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
Drywall - Horizontal or vertical slinku2020 Drywall & Plaster 27 04-08-2010 12:40 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
