Backyard Privacy, Pergola, Lattice - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-28-2013, 10:50 PM   #1
Rewards Points: 373
I would like privacy from the neighbors. As you can see in the photos, I have a neighbor in the back, and a neighbor on the side.
I will put a pergola over the main cemented patio, which is already private from the tree and tall shrub. For the area in the photos, I would like to have a small round table. For privacy, I was thinking of using a few 4x8 lattices in an L shape. Maybe an L shape that is 12 feet parallel to the back fence and 8 feet perpendicular. The 8 feet high lattice should be high enough for some privacy. I would probably need 5 4x4 posts.
Any better ideas or photo ideas?
Backyard Privacy, Pergola, Lattice-back1.jpg   Backyard Privacy, Pergola, Lattice-back2.jpg   Backyard Privacy, Pergola, Lattice-back3.jpg   Backyard Privacy, Pergola, Lattice-back-before.jpg
greentrees is offline   Reply With Quote
Old 03-28-2013, 11:05 PM   #2
Rewards Points: 13,748
http://www.bing.com/images/search?q=...s&FORM=RESTAB#
Old 03-29-2013, 10:57 AM   #3
Rewards Points: 373
I found a few ideas from the links that were provided. The L Lattice photo with the small table is what I was thinking of but with a higher lattice. The other two photos show lattices that look like they are 6 feet high. I was thinking 8 feet high would be nice, but not sure if the area is too small for the height.
The larger L design photo looks nice, but I will not have cement laid in that area. I will thinking of putting gravel down, with a few rocks as in the photo.
To put up a lattice, do I need to use 4x4 posts with cement, or can I put a board across the top, without worrying it will not move or fall down.
Also, if there are other possible ideas, it would be helpful.
Backyard Privacy, Pergola, Lattice-lattice-t.jpg   Backyard Privacy, Pergola, Lattice-lattice2.jpg   Backyard Privacy, Pergola, Lattice-pea-gravel.jpg
Old 03-29-2013, 11:16 AM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Where exactly are you going to position these lattices? IMHO adding anything inside the fence will look awful cluttered.
I'd map it out.
Maybe a gazebo with removable fabric walls or screens you can put up or down as needed.
Old 03-29-2013, 11:30 AM   #5
Rewards Points: 373
I'd map it out.
A Gazebo would be nice, but it is a lot of wood and I wanted a simple solution.
The lattices might cause a lot of clutter also, so that was my concern. It would go inside the fence, about five feet, where the dirt area is. I could fit a 12 x 8 foot lattice structure in that area.
Ideally a lineup of scrubs would be best, but that would take several years. One thought I had was to build the lattice, plant the shrubs and than evenually take down the lattice at some point (maybe 3-5 years later). I did put a japanese maple tree on the back fence (you can see it in one of the photos), so I could possibly plant another one, but they are not evergreen.
Old 03-29-2013, 12:28 PM   #6
Stuck in the 70's
I was thinking more of a metal one. It wouldn't look as bulky.
http://images.google.com/search?hl=e...mg.dKm5je8k-1A
Old 03-29-2013, 04:42 PM   #7
Rewards Points: 373
I didn't think about a metal gazebo. I think some of these are portable, so I can put it up in the summer and take it down in the winter. And I don't have to lay any cement.
Thanks for the idea. I'll have to look online to see what might fit in the area....and also buy some shrubs to start growing.
Old 03-29-2013, 04:48 PM   #8
Looks like you have enough fencing as it is. Like the above poster said, a gazebo is about the only other option you have left outside of moving out to the country.
Metro is offline   Reply With Quote
Old 03-29-2013, 11:25 PM   #9
BleachCola's Avatar
http://www.homedepot.com/p/t/2035568...4#.UVZpJsu9KK0
BleachCola is offline   Reply With Quote
Tags
lattice privacy pergola
Privacy Screen for Backyard Pool Jim F Project Showcase 14 05-30-2013 11:59 AM
Backyard Phase III - Privacy Fence jackie treehorn Project Showcase 2 06-09-2012 12:29 AM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 11:36 AM
installing lattice as privacy screen VirginiaBlueyes Carpentry 3 04-21-2011 02:18 PM
Backyard Privacy? hammermonkey General DIY Discussions 7 10-14-2008 10:09 AM
