Backsplash Tile Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-10-2008, 03:53 PM   #1
I am going to install tile on a clean drywall surface on the backsplash in my kitchen. What should I use to adhere it? I bought mortar versabond. Now I am reading I should have gotten mastic? What is mastic?
The tile is ceramic 1 foot squares made up of small tiles. Any help is appreciated.
HuskySkull is offline   Reply With Quote
Old 10-10-2008, 03:58 PM   #2
Registered User
Termite's Avatar
I hate mastic, but for this application you could use either thinset (versabond) or mastic. Thinset gets my vote.
Old 10-10-2008, 04:04 PM   #3
Is there a pro/con to each? Is one more expensive than the other?
Old 10-10-2008, 04:22 PM   #4
Registered User
Termite's Avatar
Mastic can't be used in areas that get wet (specifically tubs and showers). Mastic makes a mess of your tools and your tile if you aren't perfectly clean. Almost every time I see tile falling off the wall, they were mounted with mastic years ago.
Thinset is easy to clean up, and forms a crystalline structure bond since it is a cement-based product. If you get it on the face of a tile you can easily clean it up before it dries. It cleans off of your tools easily.
Either would work for your application though.
Tile installation question pjpjpjpj Carpentry 7 09-21-2008 12:29 PM
Question on preparing surface for Ceramic Tile Rferret Flooring 3 07-20-2008 01:08 PM
Tile Backsplash - On Top or Behind Counter? Shandon Remodeling 10 06-10-2008 09:09 AM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 10:22 PM
HELP! Question About Lousy Tile Setting Job... EricW Flooring 10 09-13-2006 08:02 PM
