Backer Board Minimum Dimensions? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-11-2012, 05:33 PM   #1
PPBART's Avatar
Rewards Points: 295
I'm planning to install stone tiles on a portion of the outside wall of an outdoor kitchen. The tile section will be 41" high. Backer board seems to be available around here only in the 3'x5' size. My only question about installing the board is will there be any problems with running the boards horizontally (3' dimension high) and adding a 5" piece at the top? I've never worked with backer board and simply don't know if there are minimum dimensions for each piece (and none of the manufacturer's literature mentions this).
PPBART is offline   Reply With Quote
Old 07-11-2012, 05:38 PM   #2
What kind of surface are you attaching the backer board to?
CopperClad is offline   Reply With Quote
Old 07-11-2012, 05:49 PM   #3
PPBART's Avatar
Rewards Points: 295
Pressure treated studs on 16" centers.
Old 07-13-2012, 12:13 PM   #4
PPBART's Avatar
Rewards Points: 295
Nobody has an answer? Hard to believe that every backer board installation fits neatly to 3'x5' (!)
Old 07-13-2012, 12:51 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Go for it! Not an issue. Be sure to use the approved backerboard screws, that's all there is to it.
installing hardy backer board for floor tile installation popeyemike Tiling, ceramics, marble 12 03-31-2012 04:02 PM
Some uneven spots on backer board scotte1975 Tiling, ceramics, marble 5 02-24-2012 02:55 PM
re-using concrete backer board caldew Kitchen & Bath Remodeling 2 02-24-2012 07:36 AM
Backer Board Thickness poolecw Flooring 3 10-09-2008 02:30 PM
tile backer board yudamann Flooring 1 06-29-2006 08:53 PM
