Backer Board Around Tub Deteriorated - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-16-2011, 11:56 AM   #1
I noticed a tile in my shower was loose, so I figured I would pull it off and reattach it. When I pulled it off I found water had gotten behind the tile and deteriorated the backer board behind it. So now there is nothing to attach the tile back too.
Do I have to replace the entire wall of backer board? Then re-tile? Or is there a way to replace just the lower portion for the tiles to attach too?
I'm sure there is no leak as the board is intact and fine above.
Thanks!
devnull88 is offline   Reply With Quote
Old 05-16-2011, 01:24 PM   #2
Rewards Points: 5,336
What exactly is behind the tile? You say "backer board", but it's a generic term. What is it made from? Concrete, sheetrock, James Hardie board?
Ron
Old 05-16-2011, 09:13 PM   #3
Rewards Points: 162
Something caused the substrate material to fail. Make sure you identify the source of the water intrusion before sealing it back up. As far as how high to go, go high enough until you have solid material behind your tile.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 05-16-2011, 09:18 PM   #4
Rewards Points: 558
how old is your home? are you sure it's now green board?
epson is offline   Reply With Quote
backer board over tile? killmenow Tiling, ceramics, marble 3 10-23-2010 12:42 PM
5/8" Fireboard (Paint) meets 1/2" Cement Board (Tile) LeviDIY Building & Construction 9 02-09-2010 09:41 PM
Connecting Ledger Board to Vertical Stud Alzipski Building & Construction 3 11-04-2009 02:53 PM
caulking between backer board and plastic shower pan ponch37300 Remodeling 6 04-10-2009 10:38 PM
Backer Board Thickness poolecw Flooring 3 10-09-2008 01:30 PM
