Back Patio Landing Advice/Ideas - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-23-2013, 03:28 PM   #1
Topic Hunter
Focker's Avatar
Rewards Points: 79
I have a sliding back door to a large covered patio (30yr old home). The threshold is a problem for older guests...That first step down is horrible for them (Grandma). I'd like to build a wooden landing with a hand rail over the existing step. The step will never see snow or water so I'm not worried about seepage into the dining room. From what I understand, I should build out from the opening 34" (The door is 36")...Is this necessary? I was thinking 24" (Current step is 17") and I'm looking for a way to do this without anchoring posts into the patio.
Thoughts? Please don't blast me with code rules...I can always remove it if/when we sell.
Focker is offline   Reply With Quote
Old 04-23-2013, 03:39 PM   #2
Rewards Points: 6,095
why not just make a wooden rail, attach it to the house and drill
through the cement to anchor it. I find nothing wrong with the depth
of the step. The height you have there already looks to be higher
than normal.
cladding it with wood, will make it even higher.
Think about painting it and paint the rest of the patio as well.
Two Knots is online now   Reply With Quote
Old 04-23-2013, 06:25 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
I would use 3 risers (equally spaced, 5.5" more or less per riser) and three threads. treads should be around 14.5" (two 2x8's), could make it wider though ...... this should be comfortable for older guest, I know I would be
top thread level with inside floor, this should put you past the concrete step. set your stringers at about 16" center to center
do understand however that code requirements usually come about because of injuries or other things that go wrong ...... thus the reasons for a landing at least as wide as the opening, and extending out 36" in the direction of travel. I know, I know you didn't want codes, sorry
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following 2 Users Say Thank You to GBrackins For This Useful Post:
Focker (04-23-2013), Willie T (05-04-2013)
Old 04-23-2013, 06:36 PM   #4
Topic Hunter
Focker's Avatar
Rewards Points: 79
Would you go the whole width of the slider? I just recently thought of going 40" wide... Dunno?
Old 04-23-2013, 06:42 PM   #5
GBrackins's Avatar
actually I'd go a little wider so that I could put in a handrail attached to the wall on each side. could be used as a "bench" for sitting except when those with mobility issues need to use it
Gary
The Following 3 Users Say Thank You to GBrackins For This Useful Post:
Focker (05-18-2013), mae-ling (04-23-2013), Willie T (05-04-2013)
Old 04-23-2013, 07:51 PM   #6
Just my 2 cents, if you don't go as wide or wider than the slider, I think it will look weird.
Maybe I am misunderstanding.
oldhouseguy is offline   Reply With Quote
The Following User Says Thank You to oldhouseguy For This Useful Post:
Focker (04-23-2013)
Old 04-23-2013, 08:59 PM   #7
Topic Hunter
Focker's Avatar
Rewards Points: 79
Originally Posted by GBrackins View Post
I would use 3 risers (equally spaced, 5.5" more or less per riser) and three threads. treads should be around 14.5" (two 2x8's)...
top thread level with inside floor...
I like these ideas and your feedback on code/safety.
I picked up the lumber and was planning on using 4X4's as legs, 2X6's as joists and 2X8's for treads as you suggested. But when I was doing a mock up I discovered I could use the 2X8's as joist's just sitting on the step and patio (NEVER gets wet). My only change is to use 2 risers VS your 3.
The top of the tread will be a slider height.
Using (1) 2X4 and (2) 2X6's as treads will give me the 14.5" you suggested.
You understood correctly and I agree...Too weird.
Old 04-23-2013, 09:22 PM   #8
Rewards Points: 2,210
better to haver a gap in case the step shifts so 2x6 may be better in this case then 2x8 right on the steps.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
Focker (04-23-2013)
Old 04-23-2013, 09:28 PM   #9
Concrete & Masonry
Rewards Points: 536
I realize that you're trying to keep this as simple as possible, but there's a good reason the existing risers were awkward: It's not because the step wasn't flush with the interior floor but that the risers were, and will still be, too high. Effectively, your mock-up proposed steps don't solve this problem at all, they just move the problem outside a foot. You really need to make a total of 3 risers out of that transition if you want it to be comfortable for anyone over age 40, and safe fro anyone over age 60.............
jomama45 is online now   Reply With Quote
The Following 2 Users Say Thank You to jomama45 For This Useful Post:
Old 04-23-2013, 09:37 PM   #10
Topic Hunter
Focker's Avatar
Rewards Points: 79
Great points. The main problem is they trip over the stupid slider track...It doesn't help that the first step out of the house is a big drop.
I'll consider your advice...I'm not afraid of the extra work...I just had an epiphany during mock up.
Old 04-23-2013, 10:05 PM   #11
www.inspectorzo.com
Send a message via Skype™ to InspectorZo
Talking
Hey there,
You're getting lots of good ideas, so I will not repeat a single one... hehe.
Also, I promise not to code slap you. I get what your looking to do.
I chimed in to add a single point. If you intend to use non-treated lumber against/over the concrete, place them over some 30lb roofing paper to prevent quick decay.
Good luck,
InspectorZo
InspectorZo is offline   Reply With Quote
The Following User Says Thank You to InspectorZo For This Useful Post:
Focker (04-23-2013)
Old 04-23-2013, 10:19 PM   #12
Topic Hunter
Focker's Avatar
Rewards Points: 79
Good luck
Great tip will do...I'm planning on using exterior house paint with primer.
Old 04-24-2013, 12:22 AM   #13
Topic Hunter
Focker's Avatar
Rewards Points: 79
I'm sorry for this dumb question, are you including the tread in the riser height? Basically I just have to have 3 platforms of equal height?
Old 04-24-2013, 07:06 AM   #14
GBrackins's Avatar
3 platforms of equal height, so yes the thread's thickness is included
Gary
The Following User Says Thank You to GBrackins For This Useful Post:
Focker (04-24-2013)
Old 04-24-2013, 07:36 AM   #15
Rewards Points: 2,516
Before and After. All we did was basically build 2 boxes out of 2x8 PT lumber then attach one on top the other. Used the composite decking for the treads and skirting.
These are not attached to the house. They are sort of 'free standing"
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
Focker (04-24-2013)
Replacing single step out back porch to patio atcstretch Building & Construction 1 04-02-2013 11:24 PM
Building a paver patio, questions about process and design NewHomeDIYGuy Landscaping & Lawn Care 11 03-30-2013 08:25 AM
New patio cover and/or enclosed patio jcrizzy Building & Construction 9 01-28-2013 12:30 AM
12-18" Spacing Between Foundation And Paver Patio Bad Idea? ErikU19 Landscaping & Lawn Care 3 04-09-2011 09:20 AM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
