Back Light Glass Tile - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-20-2012, 09:45 PM   #1
Back light Glass Tile
Any Ideas On How To back light Glass Tile? IE Does Translucent Thinset Exist?
RoyerDesigns is offline   Reply With Quote
Old 12-20-2012, 09:54 PM   #2
DIY staff
Rewards Points: 7,174
This better be a high paying job---because you will need to remove the tiles from the backing in order to avoid seeing the mesh---I suggest you contact the makers of epoxy resins--that will work for you---epoxy resin will bond glass to glass--
you may need to grind the backs of the tiles so no voids remain when epoxied to the glass backer---grout could flow under the tiles if you don't--
Are you committed to this or just checking out the possibilities?
Old 12-20-2012, 10:12 PM   #3
Hi oh'mike, A little of both to your question "Are you committed to this or just checking out the possibilities? I'm looking to see if there is any strong possibilities to this ideas and looking to budget it into the job.
Old 12-20-2012, 11:57 PM   #4
Rewards Points: 13,300
Just google back lit tiles, lots of sites come up.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
Hot wires on both sides of switch RedRumLoki Electrical 4 11-20-2012 10:37 PM
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 09:03 PM
confusion with track light stephenbishop Electrical 7 03-10-2012 02:37 PM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 01:35 PM
