AW 2579514 Door Lock Failed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-18-2010, 07:20 PM   #1
AW 2579514 door lock failed
I have AW 2579514 door lock in our side door. We could not lock the door, since the nob is rotating full. How do we repair this.
unni is offline   Reply With Quote
Old 07-19-2010, 09:14 AM   #2
Rewards Points: 5,336
Is this an Andersen window(AW) lock? If not, you need to supply a little more information.
If this is an Andersen lock with a deadbolt, the spindle sounds like it broke. When you say knob, are you referring to the deadbolt knob?
Ron
Old 08-28-2010, 02:03 PM   #3
Ron6519,
I have the same problem. The only markings on the door is and AW so I don't know if the manufacturer is A.W. Hastings or Andersen Windows. The problem is that the "T" style knob is connected to the locking mechanism in the door by way of, what amounts to, a square keyway. It appears that the keyway is held in place, in the lock, by a small cylindercal piece that has twisted off the end of the keyway.
To lock the door one is required to lift the interior handle before the "T" knob can be turned to lock the door.
Is it possible to post some pictures on this chatroom to clairify the problem?
Thank you,
Smittie
Smittie is offline   Reply With Quote
Old 08-28-2010, 04:23 PM   #4
Originally Posted by Smittie View Post
Ron6519,
Thank you,
Smittie
At the top of this forum are instructions about posting pictures.
Ron
Old 10-15-2011, 02:14 PM   #5
Ron6519,
Thank you,
Smittie
Were you able to fix your door? I also have a similar problem. Mine doesnt open because the corner ear deadbolts wont disengage and the door handle is stuck. The middle deadbolt twists on and off okay. Any ideas?
fightdk is offline   Reply With Quote
Failed inspection justlosther Electrical 66 05-27-2010 09:06 PM
caulk failed boston_michael Kitchen & Bath Remodeling 5 11-21-2008 05:30 AM
Help!? Possible failed joists under bathroom Ski-Age Flooring 2 10-26-2008 05:27 PM
Failed inspection pjm Plumbing 9 05-09-2008 04:09 PM
Failed framing inspection Hope I can sleep tonight!! NJlumberjack Building & Construction 14 01-16-2008 07:50 PM
