Old 09-12-2012, 01:45 PM   #1
Austin
Hello all. I would like to ask a question concerning bracing for a pole barn. I have built a 10x20 pole barn with 6 6x6 posts placed 10' apart. Would 3 single 2x10's be enough cross bracing to keep the walls from spreading from roof weight? I would like to stay away from a ridge beam and/or rafter ties.
mushroom hunter is offline   Reply With Quote
Old 09-12-2012, 01:54 PM   #2
GBrackins's Avatar
Austin
if you do not want a ridge beam or rafter ties have you considered roof trusses? this is typical for a post-frame building
http://www.postframeadvantage.com/
check out the EDUCATION link
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is online now   Reply With Quote
Old 09-12-2012, 04:42 PM   #3
Austin
I have already installed rafters with 10/12 pitch. I used 2x4 rafter ties 1/3 up and these are in the way of a small loft area I installed above the tack room. There is only about 2.5' of clearance above the floor to the ties. With the 2x10's already bracing the tops of the 6x6's I thought that might be enough lateral support and I could remove the ties above the loft floor. I wonder if the roof and walls will still be supported enough?
New Member - Dave - House Medic of Austin dmauldin Introductions 3 10-02-2011 07:24 PM
Just found this forum. Based in Austin, TX. AustinPainter Introductions 4 09-05-2011 07:35 PM
Howdy from Austin Broughton Introductions 2 08-01-2011 10:40 PM
Hello from Austin Deavis Introductions 3 09-05-2007 04:52 PM
Greetings from Austin austinbirdman Introductions 4 01-05-2007 06:09 PM
