Auralex Resilient Channel - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-09-2010, 09:45 PM   #1
Auralex resilient channel
Has anybody used this stuff before. I am getting ready to build a cabin for my own use and thought I might soundproof between up and down stairs and bathrooms. This stuff is pretty cheap (compared to sound proof insulation which I do not like to use in floor joists to much stuff in there ). Anyway how good does it work and can I really put it on 24" centers on the ceiling ( I know the instructions say I can but is it strong enough). My floor joists are going to be 11 7/8" bci 6000 1.7 df 16" on center.
warnerww is offline   Reply With Quote
Old 02-10-2010, 06:39 AM   #2
Remodeling Contractor
you install it perpendicular to the existing joists. It works but using something like QuietRock drywall will work much better. If installing 24" OC then use 5/8" sheetrock.
Old 02-10-2010, 05:47 PM   #3
I have been reading about quietrock es. It sounds great ( it is cut like normal sheetrock ). But I can not find a price on the stuff anywhere. I called a couple of places and they do not carry it. Does anyone now about how much this stuff costs. I realize it will vary from location to location but I am trying to get a ball park figure so I can decide if it is worth my time to pursue it.
Old 02-10-2010, 10:12 PM   #4
About 3-4 times the cost of regular sheetrock with 5 times better sound deadening.
Resilient Channel For Basement Ceiling Stingray Remodeling 7 02-07-2010 01:14 PM
soundproofing a basement rec room jtim1152 Remodeling 3 09-10-2009 05:01 PM
How-To: cut a channel in concrete? vsheetz Building & Construction 7 01-31-2009 02:21 PM
How to install resilient channel on ceiling Bcoleman6 Building & Construction 1 08-22-2008 03:29 PM
Channel Modulator BigE Home Theater 4 11-11-2007 09:15 PM
