"auger Style" Deck Supports - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-12-2008, 12:02 PM   #1
Rewards Points: 270
"auger style" deck supports
can someone help me find this on line - saw this on a home reno show last week - steel posts with a kind of a "flat" auger blade on the end - the post itself looked like it might be 4 or 5" in diameter (guessing) - they drilled these things down about 5 or 6 feet like a normal auger - and then just left in place. Apparently the post can support something like 5 tons once it's anchored...? no concrete, or digging - drill 'em down and go....
sorry I just caught a few seconds of this in the middle of some other distractions and the details are sketchy - just curious to know a bit more about this system
thanks
-randy
rtoni is offline   Reply With Quote
Old 11-12-2008, 12:34 PM   #2
Sounds like a helical pier or mini helical pier. They typically require a special hydraulic attachment on a skid steer or similar equipment to screw then into the ground. Many hardware stores cary smaller ones used to anchor structures down so wind won't blow them away.
KHouse75 is offline   Reply With Quote
Old 11-12-2008, 01:00 PM   #3
Rewards Points: 270
KHouse75 - that's the one - had no idea what they were called and a quick google on your keywords now turns up a ton of stuff - thanks very much for the quick reply
Old 11-12-2008, 01:32 PM   #4
concretemasonry's Avatar
Rewards Points: 2,608
That system is very dependant on the soil type and the moisture in the soil (especially with seasonal conditions)
The concept has been used for years by engineers, but it has to be used properly in the right soil.
concretemasonry is offline   Reply With Quote
Old 11-12-2008, 02:24 PM   #5
Rewards Points: 270
gotcha - just digging around for info - this one seemed kinda cool - something you could screw down beside existing (crappy) piers without a lot of digging, etc.
appreciate the feedback
-randy
Sagging concrete pool deck Immolate General DIY Discussions 1 06-11-2008 09:16 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Deck at seasonal camp site... Spike99 Project Showcase 0 12-24-2007 03:09 PM
Roof used as a deck - what is a good approach rogersor Roofing/Siding 3 09-19-2007 01:05 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 07:12 PM
