Attic Ventilation W/ Blocked Rafter Bays - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-30-2010, 05:20 PM   #1
Attic Ventilation w/ Blocked Rafter Bays
Hi all,
I'm in the process of converting the kneewall attics in my Minneapolis (brrr!) home from conditioned to unconditioned spaces. Upon tearing out the nasty old rafter insulation, I discovered that the rafter bays are blocked with wood near the eaves, here's a picture:
The rafter bays between the roof and second floor living area are also blocked, stuffed with fiberglass batts. I don't think I can remove these without pulling up the roof, and winter isn't exactly the best time for that!
Given all this blockage, are my soffit and ridge vents doing anything for me? How should I ventilate the attic to avoid moisture problems after blowing insulation into the floors and kneewalls?
sorghumking is offline   Reply With Quote
Old 11-30-2010, 06:51 PM   #2
An old Tradesmen
Rewards Points: 7,826
Moved to building and Construction. You might get some ideas here
Old 11-30-2010, 07:27 PM   #3
Gable Vents.
jcollin is offline   Reply With Quote
Old 12-01-2010, 04:15 AM   #4
KCB
I see your point your heating/cooling bill will drop quite a bit .How many square feet are you heating/cooling in the attic?Take a picture of the outside , do you have boxed sofits or is the rafter covered directly by the Fascia Board?
KCB is offline   Reply With Quote
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-02-2010 11:38 PM
Old Basement venting & Attic Ventilation RyanPaq HVAC 0 11-16-2010 04:10 PM
Improve attic ventilation? Greenmaze Roofing/Siding 28 07-22-2010 02:16 AM
attic ventilation lou1968 Roofing/Siding 5 05-31-2009 09:33 PM
Moving Attic Access -- Same Rafter or Different ?? wrldruler Carpentry 1 10-19-2008 06:03 PM
