Attic Ventilation Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-28-2010, 04:01 PM   #1
Attic ventilation question
House is over 100 yrs old with slate roof and gable vent with an addition added (where other gable vent was). In new attic addition, now have soffit vents and a ridge vent connected by vent trays. Getting a lot of moisture in both attics.How to get rid of moisture and have appropriate ventilation?
noblel is offline   Reply With Quote
Old 12-28-2010, 06:28 PM   #2
Registered User
Rewards Points: 5,498
Where are you located?
The exhaust and intake vents should not be connected with baffles unless in a cathedral ceiling, then a 1" gap between baffle ends.
Gary
Improve attic ventilation? Greenmaze Roofing/Siding 28 07-22-2010 02:16 AM
attic insulation question phil.grass Building & Construction 6 03-01-2010 10:56 AM
Attic with no ventilation mcgids Building & Construction 3 06-04-2008 06:07 PM
attic ventilation design help Noreaster Roofing/Siding 15 04-30-2008 08:31 PM
Attic Ventilation Questions AllGoNoShow Roofing/Siding 4 11-26-2006 12:02 PM
