Old 06-02-2011, 03:03 PM   #1
attic ventalation question
Hello there
I live at 9000 ft in thr Rocky Mountains....my attic sqare footage is 1620 sq ft...I have 3 Turtle vents and 3 Gable vents(15x20)...no soffit vents...should I put some soffit vents in???
Thank you for your time
bulldogsydney is offline   Reply With Quote
Old 06-02-2011, 03:54 PM   #2
SteelToes's Avatar
Cool air its drawn from soffit vents by a power fan or ridge vents.
Gable vent works by creating a draft thru the attic by being installed on both ends of the house...
I prefer soffit vents in combination with ridge vents or power (attic) fan.
You can also add an attic fan (as close as possible to the ridge) now to draw more air from the gable vents but still it will not be effective as a ridge cap.
Close the gable vents off and install a power fan in combination with soffit vents
http://www.airvent.com/homeowner/pro...it-specs.shtml
or ridge vent instead.
SteelToes is offline   Reply With Quote
2nd Remodel project question about attic WOOD KevRU Carpentry 18 04-12-2011 01:22 PM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 05:17 PM
Attic Baffles Question AtticBaffled Roofing 3 06-05-2010 06:00 PM
Attic Insulation question nomad4137 HVAC 1 09-06-2009 07:48 PM
Attic Venting/Insulating Question gregt848 Building & Construction 1 11-25-2007 03:33 PM
