Old 06-12-2009, 03:54 PM   #1
attic vent questions
I have an approx 1500sf hip roof on a single story ranch and I'm about to install an electric attic vent in place of the middle of 3 current passive vents which are only about 50si each and have a few questions.
First, what is the best way to block off the other 2 passive vents so the fan does not suck air from them? I'm not reroofing soon so external appearance will probably remain the same. I do have a partial bundle of shingles though if its not too hard to patch. (I'm adding plenty off soffit vents so I'll have adequate intake)
Second, what kind of roofing nail should I use? There seems to be so many types and I'm not sure which to get?
Thanks!
Grimace is offline   Reply With Quote
Old 06-12-2009, 08:16 PM   #2
Kyle Emerick
kemerick's Avatar
Depending on whats on the back/underneath, I would plywood under (in the attic) and then fill the outside with the correct thickness of wood so it does not stick up.
Regarding the nails, make sure you dont use ones that are too long. I have made the mistake before and it makes it interesting when you bump your head when using the attic.
My constant project is my home which was built in 1947. I have remodeled almost all of it and am in the process of finishing off a 1000 square foot addition. Lars Construction got me up to drywall and I am doing the rest. You can see many galleries of it
under Galleries and then House.
kemerick is offline   Reply With Quote
Old 06-12-2009, 09:54 PM   #3
Moderator
Use 1-1/4" hot dipped galvanized roofing nails. The nail point is required to come through the sheathing if 1/2" or 5/8". Use 3/4" sheathing, the nail is required to go 3/4" into it, no shorter. That is why you should see nails when 1/2" ply or 7/16"osb is used, if not , improper nail application.
Read the shingle wrapper. Be safe, G
Old 06-13-2009, 07:59 AM   #4
Don't know much about these fans but I would do some homework before taking the big plunge. A fan with no air inflow only creates a vacuum.
Could you solve this by adding more top vents and increasing intake through soffit area? There needs to be a balance of flow coming in as well. Try re posting this under roofing for more feedback
Didn't see what are you live in, is the heat extreme?
Check out this site www.buildingscience.com for attic ventilation inf.
o
Chemist1961 is offline   Reply With Quote
toilet wet vent questions (with sketch) Queso Bandit Plumbing 3 03-28-2009 08:15 PM
Soffit Vent Sizing - Really Hot Attic dmo069 Roofing 7 12-04-2008 10:33 PM
HOT attic, ridge vent/soffit vent questions gone_fishing Roofing 36 07-14-2008 10:26 PM
is an attic vent required for cedar shingle roof? walenta Building & Construction 2 10-25-2007 11:31 AM
