Attic Vapor Barrier Plastic Sheeting - Becomes Brittle Due To Heat? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-14-2011, 01:39 PM   #1
Attic vapor barrier plastic sheeting - becomes brittle due to heat?
I plan to put a vapor barrier down on the unfinished floor in my attic, then add unfaced fiberglas batts (I have free unfaced batts avail).
Thinking of using the basic 6mil clear plastic sheeting, but I'm worried about it drying out and cracking to pieces due to the heat (gets hot up there in the summer!).
Will this plastic get brittle and crack to pieces in, say, 10yrs?
thanks
rrr1 is offline   Reply With Quote
Old 12-14-2011, 01:41 PM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
Heat tends to make things more pliable, not brittle. Your attic would have to get impossibly hot to start changing the structure of plastic (melting).
hyunelan2 is offline   Reply With Quote
Old 12-14-2011, 02:03 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Lay a piece of plastic out on the sun for awhile. Heat is very determental to plastic sheeting.
Edit: or maybe it's the UV rays that break it down, now that I think about it.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-14-2011, 02:15 PM   #4
Rewards Points: 5,336
Left undisturbed, I don't see a problem.
Ron
B. Franklin 1759
Old 12-14-2011, 07:55 PM   #5
Rewards Points: 2,646
So you will have ( bottom to top ) first your interior ceiling, which is perhaps 5/8" drywall, then the vapor barrier, then a whole bunch of insulation. The vapor barrier should be roughly the same temperature as your interior ceiling, which is roughly the same temperature as your living area.
SPS-1 is offline   Reply With Quote
Old 12-15-2011, 09:26 PM   #6
Registered User
Rewards Points: 526
The v.b. should not be on the attic floor. If in a heating climate= next to the ceiling, cooling climate= above the insulation.
Gary
Old 12-15-2011, 10:11 PM   #7
Rewards Points: 1,092
There are also better plastics than standard "visqueen". Google vapor barriers, and look for Swedish or German ones. There is also MemBrain. All of these should last longer. NOW.... are you sure you NEED a vapor barrier, and not good air sealing and a vapor retarder? Are you ever going to run air conditioning? If you are in a colder place, it is recommended by some to blow cellulose over those marginal fb batts to "seal" them; better, anyway.
Any thoughts on using attic heat? 52Caddy Green Home Improvement 16 08-12-2012 12:12 AM
Plastic Sheeting to cover a wall / ceiling meowingthings General DIY Discussions 4 09-02-2011 08:12 AM
plastic sheeting bignick36 Landscaping & Lawn Care 1 08-23-2011 05:45 PM
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 05:38 AM
hot water heat attic central air...hot basement in summer spttrac214 HVAC 2 02-29-2008 05:24 AM
