Attic Vapor Barrier - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-08-2010, 04:18 PM   #1
Rewards Points: 640
attic vapor barrier
Should there be a vapor barrier between the atic and the conditioned room below it? Be it plastic liner or faced insulation with the face down? Thanks!
BlueBSH is offline   Reply With Quote
Old 03-08-2010, 05:19 PM   #2
concretemasonry's Avatar
Rewards Points: 2,570
Yes. In your climate a vapor barrier should be on the warm side of the insulation as a simple answer.
A definition of a vapor barrier is not absolute, but is just a number selected to separate materials between being "vapor barriers" and not being " vapor barriers". all it takes is 1/2 mil of thickness to throw poly into a differen category even though they have a range from .5 to 6. Other materials can be much better. - On top of this is the installation that is even more importanr in the real world. Multiple layers may be used if the difference is below a specified limit, but few people are able to handle the calculation and design.
Dick
concretemasonry is online now   Reply With Quote
Raccoons in the attic electricpete Pest Control 17 05-12-2011 05:02 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 01:42 PM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 06:06 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
Attic Frost cougar01 Building & Construction 5 01-28-2009 09:33 AM
