Attic Room - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-26-2012, 03:05 PM   #16
Rewards Points: 502
Originally Posted by cortell View Post
view this episode of Holmes on Homesl
Tried this link and couldn't get any of the videos - pity, because they sound interesting.
tony.g is offline   Reply With Quote
Old 04-26-2012, 03:19 PM   #17
cortell's Avatar
Rewards Points: 504
Huh. I just tried the link and it worked (you're first subjected to a 30 second commercial). You might want to try with another browser or even another computer. The jist of it is that a couple hires a contractor to turn part of their trussed roof into an extra bedroom. The contractor, after considerable expense, creates a partial and structurally unsound mess of a room. The guy in the overalls (I said in another thread I wouldn't mention his name again ) ends up having to cut open half the roof, restructure it using massive PSL beams that have to be lowered in by crane. He ultimately creates a pretty impressive bedroom. I have to guess the whole operation was in the $80K-$100K range, which is insane for an extra bedroom (and this was repeatedly said throughout the show). Thus, my words of caution to the OP.
cortell is offline   Reply With Quote
Old 04-26-2012, 03:58 PM   #18
GBrackins's Avatar
Rewards Points: 2,108
I'm new to the forums so I hope I'm not stepping on any toes, but per section R802.10.4 of the 2009 International Residential Code (basis for most state building codes) truss members shall not be cut, notched, drilled, spliced or otherwise altered in any way without the approval of a registered design professional. This means get a professional engineer.
GBrackins is offline   Reply With Quote
Old 04-26-2012, 05:32 PM   #19
JOATMON
ddawg16's Avatar
Rewards Points: 1,146
Tom....what part of the country are you in? (helps to put that in your profile).
I have to side with the Garage idea as well. No reason you can't go 2-story like I did.
ddawg16 is online now   Reply With Quote
Old 04-27-2012, 02:23 PM   #20
@GBrackins, Thanks for the reference! I knew it had to be in there somewhere.
@ddawg, I am in the Tampa Bay area. No worries about snow here, but definately winds.
Thanks everyone for the continual stream of good advice, suggestions, cautions, etc.
tomascg is offline   Reply With Quote
Old 04-27-2012, 02:34 PM   #21
GBrackins's Avatar
tomascq,
you're welcomed, a professional engineer could re-design your W truss into an attic room truss. I would check with the local building department and ask them if they know of a professional engineer that specializes in residential construction. Not all professional engineers do this sort of work.
Old 04-27-2012, 02:36 PM   #22
GBrackins's Avatar
and I believe you are in a 120 mph basic wind speed zone. there will be quite a bit of lateral load from that depending on the wind exposure category (depending on how close to the gulf you are).
Old 04-28-2012, 10:29 PM   #23
Registered User
Rewards Points: 5,236
I doubt very much you have any added bearing for the interior room walls below the attic other than standard framing for a truss roof. If the trusses span exterior-to-exterior, there would be no need/with added cost for the builder to install such. Consult a S.E. as many have said. Let us know the outcome!
Gary
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 09:49 AM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 04:07 PM
Raccoons in the attic electricpete Pest Control 17 05-12-2011 05:02 AM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 08:28 PM
Running coax from attic to room below, via exterior wall? curls00 Electrical 13 08-15-2007 03:18 PM
