Attic Remodel - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-11-2007, 09:08 AM   #1
Attic remodel
I'd like to turn my large attic into a spare bedroom, but I'd have to remove some of the 2x4s. Attached is a sketch of how the 2x4s are setup...the base of the triangle which supports the 2nd floor ceiling is about 40 feet. Is this a truss? If so is it possible to convert it into a stick roof or some other solution without replacing the entire roof?
NailingStuffIsFun is offline   Reply With Quote
Old 11-11-2007, 01:32 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
It's a truss. Don't touch them, don't cut into them, don't alter them.
If you want to add onto your 2nd floor, contact an architect/engineer.....
- Build Well -
Old 11-11-2007, 01:38 PM   #3
thanks
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 19 08-23-2016 05:36 AM
Ranting about attic work IvoryRing Electrical 6 04-16-2008 07:21 AM
Attic Insulation jim_arnau Building & Construction 13 11-07-2007 08:59 AM
Running Romex in the attic mdalli Electrical 7 07-06-2006 05:35 PM
Air duck from basement to the attic MageMinds HVAC 2 04-26-2006 12:41 AM
